Old Anderson Sashes Coming Apart - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-07-2013, 01:06 PM   #1
Amateuralex's Avatar
Rewards Points: 270
old anderson sashes coming apart
We have some 1977 Anderson single hung windows. A few of the sashes are coming apart. Gaps in the corners. The sashes are wood, but the frames are vinyl.
Can I just get some vices and squeeze them back together, or is this a lot more complicated than that? Surprisingly, I couldn't find much on the internet about this. Replacement windows are coming in the future, but not for another year or two.
Amateuralex is offline   Reply With Quote
Old 06-07-2013, 08:41 PM   #2
DIY staff
Rewards Points: 7,174
Going to need a picture---if the wood is rotting and puffing up the vinyl skin---you are in for some advanced cabinet work---the wood will need to be replaced.
Old 06-07-2013, 09:22 PM   #3
Rewards Points: 270
It's not in great shape but its not rotted and swollen either.
Old 06-08-2013, 06:24 AM   #4
DIY staff
Remove the sashes and see what's going on---the wood looks good--perhaps some regluing is all that is needed.
Old 06-08-2013, 06:45 AM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 194
It looks like the wood was stained before the window was assembled, if so it may be best to scrape some of the finish off where the glue can get a firm grip.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (06-08-2013)
Old 06-08-2013, 07:09 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,954
Those windows are pretty straightforward when it comes to getting them out.
Before I invested a bunch of time and effort fixing them, I would check into and see what they have (Andersen) in terms of replacement parts with updated glass.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 06-08-2013, 08:48 AM   #7
Rewards Points: 270
Originally Posted by Windows on Wash View Post
+1
Ah replacement sashes? I've read about this. Cheaper than replacement windows? I can hopefully get double pane energy efficient types? I called one local Anderson dealer and they were very coy. Special order, long lead time (several months), wouldn't give me a ballpark quote, wanted me to basically go through the entire order process first.
Maybe it's time to make some more calls? If replacement sashes were under $100 I could probably act swiftly, but the vibe I got was that they are a lot more than that.
Old 06-08-2013, 08:58 AM   #8
Bill Kearney
Rewards Points: 1,174
Yep, shop around. When I get someone that wants to put me through the whole process I usually tell them, either give me a ballpark to see if it's worth continuing or I'll go buy the whole deal elsewhere. Cut to the chase.
I'd still run the numbers elsewhere though.
wkearney99 is offline   Reply With Quote
Old 06-08-2013, 09:14 AM   #9
Rewards Points: 270
Now that you mention it, it sure does eh? That might explain why they are coming apart. That's just the kind of amateur crap I see all over this house lol.
The Following User Says Thank You to Amateuralex For This Useful Post:
BigJim (06-08-2013)
Old 06-15-2013, 11:00 PM   #10
Call A/W and they can sell you new sash if thats the way you want to go. If your frames are in good condition, I would just get a conversion kit. It will basically make that DH window into a tilt wash DH. If you have grilles in the windows, they would not work with a conversion kit. Those Narroline DH windows are a pain in the sack to install if you don't know what you are doing, but the conversion kit is pretty user friendly for installation.
mknasa dad is offline   Reply With Quote
Old 06-16-2013, 03:16 AM   #11
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Andersen windows are not exactly top of the line, neither is Crestline from my examinations of them at Menards, so it doesn't surprise me they are coming apart. I compared these with Pella on the shelf and the Pella windows were much better construction.
The Crestline widow I looked at was like $50 cheaper but it was made of part chipboard or plywood I forget now, stapled together and given white primer and just bare stacked on the shelf. The Pella window was solid lumber, joined well, and shipped to Menards in a shrink wrap/cardboard protector with extra corner protectors.
Most of the times going cheap by replacing just parts gets you substandard end results. The people who had my house before me replaced all the window sashes and used vinyl tracks, cheap junk then and cheaper junk later when the windows wouldn't stay up and were either loose or too tight to open.
I replaced all of the windows frames and all completely, I think doing any less is not going to be satisfactory, but if you plan to sell the house in 2-5 years it doesn't matter.
RWolff is offline   Reply With Quote
The Following User Says Thank You to RWolff For This Useful Post:
Windows on Wash (06-16-2013)
Basement air coming up through vents and returns glsmith HVAC 7 09-05-2016 01:07 AM
Strong Odor coming from basement mas06870 General DIY Discussions 12 02-26-2013 09:11 PM
Help with stink coming from Toilet area. Integraoligist General DIY Discussions 9 11-16-2011 06:16 PM
Water coming in under bathtub thesinks Plumbing 1 07-04-2009 09:14 PM
washer and Clothes coming out of washer stink. rsplash40 Appliances 11 07-03-2009 12:05 PM
