Old Aluminum Window - Replace Brittle Sealing Gaskets - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 10:00 AM   #1
old aluminum window - replace brittle sealing gaskets
Hi,
The lower level (half-basement) of our house has seven 3'h x 6'w windows, original to the house (1967). Getting the windows replaced will not be cheap and we cannot afford to do that anytime soon.
Since we have to make do with these windows, I would appreciate some advice on repairs.
I've attached a photo of one window showing the white seal (gasketing?) between the glass and aluminum that has become brittle and is falling off. This is the same situation for all the windows. I've looked for replacement gasketing with no luck. Is it called by another name? If this kind of sealing gasket is no longer being made, what can I use instead?
Alternately could I reseal the glass/aluminum seams with caulk or is that a dumb idea?
ChrisJJ is offline   Reply With Quote
Old 05-30-2012, 12:13 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,112
Check with a local glazing shop.
You may find the repairs to be cost prohibitive but that all depends on the glazing shop and their pricing.
Insulating Aluminum Window Frames waynerlee Windows and Doors 25 04-26-2012 12:13 PM
IGU replacement in Aluminum window frame Daler Windows and Doors 2 09-15-2011 09:42 AM
Sill on aluminum window danvath Building & Construction 1 09-20-2010 10:45 PM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 03:57 PM
Window Frame Materials - Vinyl vs Aluminum vs Fiberglass chrison600 Building & Construction 2 10-09-2005 12:13 PM
