New Windows In Home - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 02:45 PM   #1
New windows in home
I have two windows that I am going to install in my home and had a few questions. First off the home was built around the 1950's and the windows are from about the same time. They are the old sliders and the aluminum frame is coming off the glass. It is a brick home with aluminum siding on about 10% of the home(from the top of the windows and up). I was going to install aluminum windows with the nailing tab around it.
I was going to cut the morter in between the bricks back far enough to get all around the window for flashing tape purposes and take out the bricks out for re-use. After this I was going to support the frame and rebuild the frame for the window since it is going to be a little bigger. Then I am going to make a sill with dupont flexwrap and then silicone and install the window and use flashing tape around it putting the flashing tape over the house wrap. After this I would re-brick the part that is cut away back up to the edge of the windows like it is now.
Sorry for the long paragraphs I am just wanting to install these windows and I want to make sure that I am installing them the right way.
Thank you for any help.
tcfls2 is offline   Reply With Quote
Old 05-04-2011, 05:42 PM   #2
If you mean the newer windows have Aluminum frames. "DON"T" do it Alum. is a very poor insulator. Complete waste of time and $$$
Nevar is offline   Reply With Quote
Old 05-06-2011, 09:17 PM   #3
Rewards Points: 5,336
Where do you live where aluminum windows are efficient? Hawaii comes to mind. Not many other places.
Ron
Old 05-18-2011, 06:33 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
My understanding is that aluminum is pretty popular in some of the warmer climate regions and works fine there. I assume that is where you are located, otherwise they would not be readily available.... What is your level of experience in doing anything like this? Your method seems pretty much on par, but it really is a pretty advanced install. Personally I would not remove the brick, as there is no way that you'll be able to redo it without it standing out like a sore thumb afterward. Old aluminum can be cut or pryed out, then on the new one, I'd build a buck frame and flash/cap it appropriately on the exterior. I've seen guys who've been able to use a fold-out nailing fin without brick removal, but it depends on how tight the fitment is.... I assume that there is no wood (or other?) trim between the window frame and the brick, correct?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 08:56 AM
Replacement Windows lucky8926 Building & Construction 36 10-13-2010 11:09 AM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 09:34 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
