Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 07-04-2011, 11:25 AM   #1
new windows on 30 year old house
looking for a little direction/ advice here
had this house built 30 years ago, brick veneer with dashwood slider windows the kind with big panes of heavey glass
they are getting tired/ old & am looking to replace
what would be the best way to go
1. remove brick mold, interior trim & cut window frames back to studs, remove & replace, re-trim & install new vinyl brick mold
2. remove glass, install replacement windows ( a little smaller ) & have them cap off the outside
just to add i am pretty handy ( don't pay too many people to do too much for me ), and really don't mind pecking away at a job like this, but bending aluminum & capping is probably out of my range
if i was to go with #1 , would i measure the old window frame exactly & order the same ? & have not checked but do they make vinyl brick mold ?
really tired of the maint/ painting thing
should add there are 10 windows all the same ( 6 the same size ) plus 1 bow window about 8' x 4' , gonna hold off on that one a bit & might get a quote to change it out
all help/ suggestions etc appreciated
thanks
bob
bobfeather is offline   Reply With Quote
Old 07-04-2011, 12:06 PM   #2
Super Moderator
Going into a brick opening with a new construction window is the best way--but rather risky.
If you blow the measurement you will be stuck with the windows.
To get an accurate measurement ,you need to remove the interior trim--this will expose the actual edges of the windows---with double hung windows -a bit of the drywall below the bottom may need to be removed,as the window bottom is usually hidden by 2 inches or so of drywall.
Then go outside and and verify the numbers by estimating the set back of the brrick molding and see if the numbers are the same.
Most catalogs list the 'rough opening' that's the size of the framed opening---you may need to call the distributor or manufacturer to get the actual size of the window.
Pvc brick mold is available just about anywhere.
Old 07-04-2011, 03:12 PM   #3
You absolutely want to get the corect measurememnts the first time. This can be a painfull process but is well worth the time. If you make a mistake and order the windows larger than you need, you'll have a bunch of extra work ahead of you. If you order too small, you have a bit of extra work but if you order the correct size, you're golden. You're always better off, at the very least, hiring a professional window repair or installation company to do the measurements or to verify your measurements. A tiny error could be quite costly.
Last edited by oh'mike; 07-04-2011 at 03:54 PM. Reason: removed ad link--read posting rules plaese
windowrepairguy is offline   Reply With Quote
Leaking Vinyl Windows in 7 year old home c3uo Building & Construction 14 04-12-2011 10:02 PM
Installing nail fin windows - house wrap and t 111 siding DirtDog Remodeling 3 03-17-2011 12:59 AM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
