Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-22-2012, 11:01 AM   #1
Braddiy's Avatar
New Window &storm door installation
Is there anything I should watch for when my windows and storm doors are installed tomorrow.
I have never used this company before, just read reviews. Canadian choice windows.
Braddiy is offline   Reply With Quote
Old 10-22-2012, 11:18 AM   #2
New constrution, or replacement windows?
Old 10-22-2012, 03:02 PM   #3
Braddiy's Avatar
Replacement windows vinyl energy star windows double paned s double slider and casement and picture window.
Old 10-22-2012, 04:26 PM   #4
If your there watching them, make sure they set a level on the bottom and the side to make sure it's all square.
Make sure there insulating any gaps before reinstalling any trim.
Replacements need a bead of caulking around the stop moulding that the windows are going to be sitting againt that keeps them from falling out of the opening.
Old 10-22-2012, 09:12 PM   #5
Braddiy's Avatar
Thanks ill be watching for all of that. Will they be removing the wood frame around the windows?
Old 10-22-2012, 09:28 PM   #6
Since no one here can see your house from here no way to tell.
Old 10-22-2012, 09:49 PM   #7
Braddiy's Avatar
I uploaded a picture of one of the old windows, they are original wood windows, I have removed trim already. Don't want contractors ripping up my walls lol.
Old 10-23-2012, 07:26 AM   #8
Windows & Remodeling
HomeSealed's Avatar
Not trying to be argumentative, but this advice is somewhat questionable in terms of determining a "quality installation".
1) Most existing openings are out of square, so setting a level on the sill may not even get you the best looking installation. Getting the new window SQUARE is of paramount importance, and often the best install may be very slightly off level so as not to look "out of whack" with the existing opening, trim, etc. The best installers that I've ever met rarely pull out a level on window installs.
2) Caulking the stop moulding to "keep the window from falling out" is a procedure often referred to as a "caulk and walk" installation, and is the exact opposite of a quality install. In fact, it is precisely the procedure that gives vinyl replacement windows a bad name. The window should be installed square, properly shimmed as necessary and secured with screws (preferrably stainless), insulated with a low expansion, closed-cell foam (preferred over fiberglass), and then capped and caulked on the exterior. Interior caulking is optional for aesthetics.
Things to look for:
-Squareness: Open the upper and lower sash (on a dh) about 1/4" each, and check the reveal (gap). It should be reasonably consistent going all the way across. Also check the weatherstripping on the sides of the sashes to make sure that it is coming into solid contact with the frame (not too tight that it impedes operation though).
-Proper sizing : You should not see the edge of your window exposed past the interior stops.
- Exterior trim and caulk: The aluminum trim (if applicable) should be installed with clean, tight, seams, and have a nice clean bead of caulk throughout. If your existing windows had a drip cap/head flashing, it should lap OVER your new trim to preserve the water management system. Many guys will just wrap right over it so that it looks a little bit nice, thereby reducing the integrity of protection to that of the caulk's lifespan.
HomeSealed is offline   Reply With Quote
The Following 2 Users Say Thank You to HomeSealed For This Useful Post:
kwikfishron (10-23-2012), Windows on Wash (10-23-2012)
Old 10-23-2012, 07:28 AM   #9
HomeSealed's Avatar
If they are indeed true "replacement" windows, the wood frame will stay and the drywall will be left untouched.
Old 10-23-2012, 09:19 AM   #10
I think your misreading my reply.
The outside stop moulding keeps the window in place not the caulking.
If the sill is level and the jamb is plumb would the window not be square?
I may be wrong but I think the O/P said they were installing replacement windows, anyone ever heard of a replacement casement winodow?
I can see replacing a casement window, but not a replacement window.
Old 10-23-2012, 10:48 AM   #11
HomeSealed's Avatar
That is true in theory (opening being level and plumb), however rarely does it translate to reality. In terms of keeping the window in place, that is the job of the shims and fasteners. The blind stop (outside stop) may or may not even be left in place. On an exterior installation, it is removed and sometimes replaced, other times installers tuck their aluminum trim right into the utility groove of the new window which is acceptable as well.
I'm not sure what exactly you are saying here, but yes, there are "replacement casement windows". The astragal stops are removed from the buck frame, and then a casement window which is 3 1/4" jamb depth and sans nailing fin (ie: "replacement casement") is installed. Interior stops are then added. Generally, a quarter-round (shoe) or cove moulding is used.
As I said Joe, I apologize if that came across as argumentative. I do not mean to assume the intentions behind your post, but just clarify a few things for the benefit of the OP and other DIY'ers.
Old 10-23-2012, 10:51 AM   #12
Braddiy's Avatar
Thanks homestead this is what I have read online also, the windows are indeed replacement windows. I may of used the wrong terminology about casement window what I ment was the windows on either side of the picture window are the ones with the little handle that you turn open.
Thanks joe for the responses.
Old 10-23-2012, 10:55 AM   #13
Braddiy's Avatar
The installers will be finishing the outside of the windows with aluminum flashing and caulking. It is brick to brick install on flashing.
Old 10-23-2012, 10:57 AM   #14
Braddiy's Avatar
One more thing they said there installing at vinyl trim on the inside around the window rather then wood..... Any thoughts on this?
Old 10-23-2012, 10:58 AM   #15
Braddiy's Avatar
It's raining today so I have to wait another week for install.
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 03:05 PM
Defog window recap greenmax General Discussion 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
