Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 08-19-2012, 02:03 AM   #1
New weatherstrip for sliding glass door
Hello all,
I've been lurking for a while and finally have an issue that I can't seem to find. I've been working on getting my kitchen ready for paint and wanted to clean up the sliding glass door. While giving it a good once over I found that the previous owner had everything painted. All of the weatherstripping was painted and in some places was caulked as well. Subsequently the weatherstripping is in bad shape and needs to be replaced. The problem is I don't know who made the door. I highly doubt it's an Andersen window since the glass is not etched with AW. The windows are etched with the following:
Gaurdian
Carelton, Mich
ANSI Z97.1-198
SGCC.933-178
16 CFR 1201 11 (Hard to read)
GGSB 12-GP-4
Safety Tempered
The door hardware looks like generic big box store hardware so that isn't any help. Thoughts?
I will try to take some pictures of the weatherstrip profiles.
info2x is offline   Reply With Quote
Old 08-19-2012, 02:29 AM   #2
A picture of the door and the seal I'm sure will help.
Old 08-19-2012, 08:22 AM   #3
Exterior Construction
Windows on Wash's Avatar
Guardian is likely the glass manufacturer.
Can you open the door an look on the jamb sides to see if you can find any labels there?
Pictures, as Joe mentioned, are helpful too!
Old 08-19-2012, 12:13 PM   #4
I'm under the assumption that Guardian is the glass maker as well. Most of my searches have come up with nothing except a glass maker and local door shops that don't seem to have anything remotely like what I have.
Pictures
This is the aluminum channel that goes on the interior side, held in by several screws. It's the same for both top, left, and right sides.
This is the weatherstripping that goes on the bottom in between the two panels. It just pushes in.
This is the weatherstripping that goes on the top between the two panels. Again there are no fasteners for this one.
This is the weatherstripping that goes on either side of the casing again between the panels.
Old 08-20-2012, 10:24 PM   #5
Here are some more pictures:
Handle set:
Interlock weatherstrip:
Old 08-21-2012, 07:45 AM   #6
I just ordered a bunch of parts from these guys and they were super helpful.
Not sure if they would have that stuff but they are worth a shot.
https://www.blainewindow.com/
Old 08-21-2012, 10:11 AM   #7
Thanks. I found them during my search and have sent them a bunch of pictures. We'll see what they come back with. Hopefully it's good news.
Old 08-21-2012, 11:44 AM   #8
By now I would have ripped out that old door and just replaced it with a new and better one.
That way I know it's not going to leak and would have a whole new roller system.
Old 08-21-2012, 03:46 PM   #9
Well Blaine didn't come up with anything .
I typically would be all for it, but money is on the tighter side right now since I'm getting married in about a week. The door didn't have any leaks when I started and the rollers were in good shape, hell those are easy to replace anyways. In the grand scheme I'm trying to get the walls and windows up to snuff in the kitchen because overall while I might no like the cabinets the layout is good and it isn't falling apart. I have other parts of the house (and garage) that I'd rather spend the big bucks on. Like I said 9/10 times I'm right there with you.
Old 08-21-2012, 04:14 PM   #10
By the time you do track down all the stuff and replace it, you might have more time and resources in the retrofit of and old door though.
Keep that in mind but I applaud your less than throw away attitude. Too bad most of the good made today are not as well built and inclined to be repairable.
Old 08-21-2012, 04:28 PM   #11
Yeah I know. It comes down to what is my time worth compared to the just putting new unit in, I'm still wrestling with that. I just hate to get rid of an otherwise good door because some bits of vinyl are crapping out.
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 10:00 PM
Moulding Around Sliding Glass Door JRMN Building & Construction 8 08-03-2010 12:22 PM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 08:22 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
Replace weatherstrip on prehung door? Missmargery General Discussion 2 09-19-2006 11:06 PM
