-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   New weatherstrip for sliding glass door (http://www.diychatroom.com/f104/new-weatherstrip-sliding-glass-door-154154/)
info2x 08-19-2012 01:03 AM
Hello all,
I've been lurking for a while and finally have an issue that I can't seem to find. I've been working on getting my kitchen ready for paint and wanted to clean up the sliding glass door. While giving it a good once over I found that the previous owner had everything painted. All of the weatherstripping was painted and in some places was caulked as well. Subsequently the weatherstripping is in bad shape and needs to be replaced. The problem is I don't know who made the door. I highly doubt it's an Andersen window since the glass is not etched with AW. The windows are etched with the following:
Gaurdian
Carelton, Mich
ANSI Z97.1-198
SGCC.933-178
16 CFR 1201 11 (Hard to read)
GGSB 12-GP-4
Safety Tempered
The door hardware looks like generic big box store hardware so that isn't any help. Thoughts?
I will try to take some pictures of the weatherstrip profiles.
joecaption 08-19-2012 01:29 AM
A picture of the door and the seal I'm sure will help.
Windows on Wash 08-19-2012 07:22 AM
Guardian is likely the glass manufacturer.
Can you open the door an look on the jamb sides to see if you can find any labels there?
Pictures, as Joe mentioned, are helpful too!
info2x 08-19-2012 11:13 AM
I'm under the assumption that Guardian is the glass maker as well. Most of my searches have come up with nothing except a glass maker and local door shops that don't seem to have anything remotely like what I have.
Pictures
http://i1070.photobucket.com/albums/...x/a60fb2e1.jpg This is the aluminum channel that goes on the interior side, held in by several screws. It's the same for both top, left, and right sides.
http://i1070.photobucket.com/albums/...x/7f0d5ac3.jpg
This is the weatherstripping that goes on the bottom in between the two panels. It just pushes in.
http://i1070.photobucket.com/albums/...x/f23b22fd.jpg
This is the weatherstripping that goes on the top between the two panels. Again there are no fasteners for this one.
http://i1070.photobucket.com/albums/...x/2f65eee9.jpg
This is the weatherstripping that goes on either side of the casing again between the panels.
info2x 08-20-2012 09:24 PM
Here are some more pictures:
Handle set:
http://i1070.photobucket.com/albums/...x/f5c1d6a4.jpg
http://i1070.photobucket.com/albums/...x/f27170c8.jpg
http://i1070.photobucket.com/albums/...x/fcedb070.jpg
http://i1070.photobucket.com/albums/...x/b539763e.jpg
http://i1070.photobucket.com/albums/...x/1b22d320.jpg
Interlock weatherstrip:
http://i1070.photobucket.com/albums/...x/65b23be9.jpg
Windows on Wash 08-21-2012 06:45 AM
I just ordered a bunch of parts from these guys and they were super helpful.
Not sure if they would have that stuff but they are worth a shot.
https://www.blainewindow.com/
info2x 08-21-2012 09:11 AM
Thanks. I found them during my search and have sent them a bunch of pictures. We'll see what they come back with. Hopefully it's good news.
joecaption 08-21-2012 10:44 AM
By now I would have ripped out that old door and just replaced it with a new and better one.
That way I know it's not going to leak and would have a whole new roller system.
info2x 08-21-2012 02:46 PM
Well Blaine didn't come up with anything :(.
I typically would be all for it, but money is on the tighter side right now since I'm getting married in about a week. The door didn't have any leaks when I started and the rollers were in good shape, hell those are easy to replace anyways. In the grand scheme I'm trying to get the walls and windows up to snuff in the kitchen because overall while I might no like the cabinets the layout is good and it isn't falling apart. I have other parts of the house (and garage) that I'd rather spend the big bucks on. Like I said 9/10 times I'm right there with you.
Windows on Wash 08-21-2012 03:14 PM
By the time you do track down all the stuff and replace it, you might have more time and resources in the retrofit of and old door though.
Keep that in mind but I applaud your less than throw away attitude. Too bad most of the good made today are not as well built and inclined to be repairable.
info2x 08-21-2012 03:28 PM
Yeah I know. It comes down to what is my time worth compared to the just putting new unit in, I'm still wrestling with that. I just hate to get rid of an otherwise good door because some bits of vinyl are crapping out.
dpm8906 09-04-2016 04:49 AM
Re: New weatherstrip for sliding glass door
I know some time has past since your original post but I have a similar door with identical weatherstripping that needs replaced. Curious how you went about your fix. I also live in SE Michigan. I believe the door could have been made by Weathervane, a company who now is defunct.
dd57chevy 09-04-2016 08:19 AM
I assuming you did a "search" to find this thread (it's 4years old !). Not sure if INFOx is still lurking or not .
He said Blaine Window couldn't help him . I would guess you'd have to fabricate something out of a generic weatherstrip (foam or vinyl) .
It won't be as durable as an OEM piece (may need to re-do it every year !) .
If you figure it out I would suggest replacing the roller assemblies while you have the door out .
info2x 10-08-2016 10:19 PM
Hey I am still around!
Well DPM I never did squat. I too found weathervane from talking with the paint store of all places. A local window shop also spoke about them. The closest I ever came was this place:
http://nevetsglass.com/obsolete_window_door_parts.shtml
Never got a call back though. Eventually I'll just replace the door with something nicer.
