New Vinyl Replacement Windows Can Be Pushed In Middle - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-11-2013, 07:30 PM   #1
New vinyl replacement windows can be pushed in middle
I had a company install Ameritech sideways sliding vinyl replacement windows today, 9 of them. They installed the windows today but will finish with the insulation and caulking tomorrow. If I push at the bottom on the middle of the windows they give a little, anywhere from 1/8" to 3/8". They placed screws on the sides but nothing on the top or bottom. Is that normal?
The windows are 4' tall and 6' wide.
elyders is offline   Reply With Quote
Old 06-12-2013, 06:11 AM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
You can't put screws through the sill as water drains through those cavities and could leak into your wall. The trim, caulk, shimming, foam, etc that they have yet to complete should take care of that. In fact, they may still be adding exterior stops prior to trimming. Either way, to answer your question, no it should not do that when the install is complete... You could politely ask the installers about it as well, which will cause them to pay extra attention to that aspect.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 06-12-2013, 06:52 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,238
The exterior caulking, if not already applied, will help lock the frame in place.
Definitely, do not put a screw through the lower middle of the window.
Old 06-15-2013, 10:02 PM   #4
If you put a screw in it, you just potentially voided your warranty.
mknasa dad is offline   Reply With Quote
Old 06-17-2013, 11:01 AM   #5
I used the spray insulation foam and that seems to have held the windows in place so there's no movement.
Old 06-17-2013, 08:05 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
You did or they did? If you were paying for these windows to be professionally installed your installers should be taking are of this. If you did indeed do it, make sure that you used the correct, low - expansion formula.
www.HomeSealed.com
The Following User Says Thank You to HomeSealed For This Useful Post:
Windows on Wash (06-18-2013)
Old 06-19-2013, 10:28 AM   #7
I asked the installer about insulation and he said he always just caulks the interior and exterior and that it works fine for him. I told him that caulk will fail after time and that he's not the one living there for 10+ years. He didn't want to put in the expanding foam, even the low-expansion stuff, because he said it'll warp the window frame. I told him to just caulk the outside and leave. I sprayed the low-expansion foam inside and then caulked the inside myself.
(That's probably why they were the lowest bid.)
Old 06-19-2013, 12:41 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Yup.... The devil is in the details as they say.
www.HomeSealed.com
Windows on Wash (06-19-2013)
Re: old buildings RWolff Building & Construction 157 01-19-2014 12:35 AM
Worthwhile to replace old wood frame basement windows with new vinyl windows? Cost? TomServo Windows and Doors 5 10-25-2012 07:10 AM
replace replacement windows theone Windows and Doors 3 10-19-2011 09:16 PM
vinyl double hung replacement windows beefaroni11560 Windows and Doors 6 07-31-2011 11:36 AM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
