New Low E Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-09-2012, 10:51 AM   #1
new low E windows
should argon filled lowE windows still ice up. I understand the condensation if there is high humidity in the house, but should I still expect ice to form. I should mention that it was -32 C outside.
Sandro22 is offline   Reply With Quote
Old 02-09-2012, 02:46 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Generally they shouldn't, however there are a bunch of things that factor into that. If it is that cold out and damp enough inside, it is certainly possible. Another factor could be if the window is leaking air, causing it to be colder. I've also seen windows mistakenly made with out the argon or low-e in some instances. It is pretty to easy to tell if it has low-e, not as much on the argon.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-12-2012, 06:28 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 894
With those type of temps...anything is possible.
Check them for proper fitment and it might be worth reducing indoor humidity levels with the temps are that low.
Old 02-12-2012, 06:34 PM   #4
Rewards Points: 12,856
Are these new constrution or replacement windows?
As anyone taken the time to caulk around the window frame on the inside?
Dual Pane Windows No Low E Glass and No Argon Gas Filling AZSun Windows and Doors 4 08-12-2011 10:10 PM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
