New Jelwen's Collecting Water Between Top Rail And Frame - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-11-2013, 11:18 AM   #16
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Certainly would not hurt to get them in the same room
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-11-2013, 12:50 PM   #17
Home Performance
HomeSealed's Avatar
Rewards Points: 712
...and btw, while im not the #1 fan of the jeldwen product, your installer is going to have an uphill battle in trying to say that this issue is product related given your description of the issue.
www.HomeSealed.com
Old 01-21-2013, 06:00 PM   #18
JelWen window update
The JelWen rep came out. The larger windows with two latches all have warped upper sashes. All need to be replaced. Believes the wood used was not dry, or stored incorrectly. Does not believe this has anything to do with the water problems, and the smaller window sashes are fine, but still dripping water.
As for the water, he believes its condensation. He checked weather stripping said it looks ok. He has never seen this problem and is checking with other reps for ideas. He wants to add stripping on top of the top sash, but this will cover the sliding latches which allow you to tip the window in for cleaning. So, not acceptable for me.
Any thoughts??? He was certain its not moisture from outside.
Now the water which was dripping is just big ice stagatites which get larger every day.
spidersmouse is offline   Reply With Quote
Old 01-21-2013, 07:54 PM   #19
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Great that he has identified the warped sashes... I do have to say that I'm very skeptical on the condensation diagnosis however given that it was 50*+ last week when you posted.
www.HomeSealed.com
Old 01-21-2013, 11:19 PM   #20
Have you checked the humidity levels?
mknasa dad is offline   Reply With Quote
Old 01-22-2013, 11:29 AM   #21
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Should be pretty easy to figure out at this point. The day that you posted previously it was 50* and rainy. Now it is 0 and drier than a bone. If you had moisture then and not now, obviously it is not a condensation issue. If you can start with a clean, dry surface now, and you end up with any moisture or ice in there, then it will be due to condensation... Although, given that he is replacing upper sashes, you might want to wait until they are installed to answer definitively. Certainly a warped sash that is leaking cold air would increase the chances of condensation.
www.HomeSealed.com
Old 01-31-2013, 09:23 AM   #22
its a flashing ( lack of flashing ) issue , not the window < installers fault
1vinylexteriors is offline   Reply With Quote
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 12:42 PM
