Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 05-12-2011, 09:06 PM   #1
New jamb liners for older windows??
I have a 1952 house with original windows. After a lot of research I've decided to update and refinish them rather that tossing them out for vinyl inserts. They have some water stains but are in very good shape with no rot so they don't need to be "rebuilt".
First I need to update the jamb liners and weather stripping. There doesn't seem to be much info available or even many suppliers of replacement jamb liners. Here are the a couple I saw:
http://jamblinersusa.com/installation.php
http://www.oldfashionedwindows.com/jamb%20liners.htm
Does anyone have any experience with this or have any advice about what jamb liners to use?
The windows are on metal jamb liners now with springs in them, so no weights and chambers to insulate. Attached is a picture of how they are now.
tartrazine is offline   Reply With Quote
Old 05-13-2011, 07:42 AM   #2
That is a lot of work to do on windows that will still be drafty and inefficient, but your choice. New jamb liners will definitely improve the operation of the window, and probably help the drafts. I would go with the vinyl liners. I have seen the others and they do little to improve anything about old windows.
The Following User Says Thank You to Just Bill For This Useful Post:
Tom Struble (05-13-2011)
Old 05-13-2011, 08:23 PM   #3
Tom Struble's Avatar
you may even want to pull the inside trim and make sure it's insulated well
Tom Struble is offline   Reply With Quote
Old 05-27-2011, 12:37 AM   #4
Hello.
I have the very similarly designed sash and jamb. Can you tell me how this sash is removed from the frame (or where I can find this information)? I need to remove the sash to work on the bottom rail.
Thank you for any advice on the removal.
ralphdibney is offline   Reply With Quote
Old 05-27-2011, 09:13 AM   #5
Window and Door installer
Originally Posted by ralphdibney View Post
Hello.
There is usually a piece of wood strip called a "stop" that, if painted, can be scored with a razor knife to separate the paint. You can then pry the stops off of each side and remove the sash. However, sometimes the wooden stops aren't small strips of wood and the casing will need to be removed in order to pull the stops off. It just depends on that particular casing job.
Jkslate is offline   Reply With Quote
The Following User Says Thank You to Jkslate For This Useful Post:
thomasjmarino (05-30-2011)
Old 05-30-2011, 09:13 AM   #6
Do you have storm windows on these units? Replacing the metal liners with vinyl will help with thermal tranference of the cold from the exterior, but adding storms, with a good weatherstripping will help more.
The exterior glazing compound on the pictured window is in need of attention. That will also cause air and water infiltration.
Ron
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
2x4 windows in 2x8 walls Jamb extension ? HELP NEEDED! THANKS!!!! compman723 Carpentry 5 06-15-2009 12:07 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
