Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 03-29-2013, 11:20 PM   #1
New interior doors and jambs
I am putting in new doors and door jambs and have come across a problem after removing the old jambs. I am left with these metal brackets that were used to plumb the old jamb. I do not know how to remove them. They are nailed into the stud and drywall very solid. There's no way I could claw out the nails without ruining the drywall. Actually i cant grasp the head of the nail regardless. What are my options and what tools would I need?
eveready11 is offline   Reply With Quote
Old 03-29-2013, 11:43 PM   #2
Exterior Construction
Windows on Wash's Avatar
Will the new pre hung clear those brackets? If so, leave them in.
Old 03-29-2013, 11:46 PM   #3
http://www.bing.com/shopping/stanley...lppc=undefined
Old 03-29-2013, 11:54 PM   #4
The previous door was cut down, so the brackets need to be removed for proper fit.
No pry bar will get under the mail or bracket to pry it out. Attempts at this would destroy the drywall.
Would a reciprocal saw cut through the bracket?
Old 03-30-2013, 12:30 AM   #5
call me E
TheEplumber's Avatar
I'd use a good cats paw and pull the nails or maybe an angle grinder and grind the heads off
Old 03-30-2013, 12:34 AM   #6
The trim is going to cover up what minor damage will be done to the drywall.
You drive the bar in from the top and the bottom not the sides.
Old 03-30-2013, 12:39 AM   #7
I can't get the nails to move. I used a flat bar to yank on the bracket and the result is the attached pic.
Old 03-30-2013, 12:41 AM   #8
Here's the pic.
Old 04-14-2013, 02:42 PM   #9
A stiletto cats paw would make quick work of those brackets. Although you will have some trouble with all of your coworkers always asking to borrow it.
one cut is offline   Reply With Quote
Old 04-14-2013, 02:44 PM   #10
Bingo.
jsbuilders is offline   Reply With Quote
Old 04-14-2013, 02:45 PM   #11
http://www.bing.com/shopping/10-in-e...iers&FORM=HURE
Please edit your profile so it shows your location!
No one here knows exactly where on the planet you may be so how can we ansewer a code, building, or insulation question without it?
Old 04-14-2013, 02:51 PM   #12
Thanks everybody. I managed this although the nails were so difficult to remove because they were threaded.
I just used a nail puller that looks like a screwdriver to get a start on it and a hammer did the rest. Tore up the drywall a bit.
Old 04-14-2013, 04:04 PM   #13
AHH, SPANS!!!
the screwdriver type puller sounds like a tack claw, one of the most used tools in my arsenal when doing repairs.
hand drive is offline   Reply With Quote
Flooring or Door Jambs first simmons2k Flooring 2 01-26-2012 08:57 PM
Building door jambs? jonesbill Windows and Doors 4 08-10-2011 09:26 AM
Replacing Exterior Door Jambs Mallen83 Windows and Doors 4 07-29-2011 10:47 AM
window jambs flush with framing porchhen9 Remodeling 3 05-15-2011 06:42 PM
Installing Window Jambs rde476r General Discussion 9 03-27-2009 05:36 PM
