New Flush Fin Windows, Recessed Stucco Arch Above Old Frame - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 02:44 PM   #1
Rewards Points: 14
New flush fin windows, recessed stucco arch above old frame
Hey everyone, first time poster here. Been working over the past year and a half to remodel my house, got most of the inside done and now I'm on to the windows.
I'm located in Phoenix AZ, have a stucco house built in 1984. Original windows are aluminum frame, and after doing some researching online I decided to go with vinyl flush-fin replacement windows to avoid cutting and patching the stucco. I have a total of 5 windows to do, but only ordered 1 to start with, figuring if that one goes bad I'm only out $400 rather than $2000
The one window that I did order is has a recessed arch above the window. I'm trying to figure out what the best way is to deal with this. I'm going to need something to fill in the gap created by the top fin on the new window and the recessed area. Do I just fill this with stucco? How do I go about sealing it? Of course I had to pick the difficult one to do first.
Pics attached. TIA!
New flush fin windows, recessed stucco arch above old frame-2011-11-23_15-33-04_526.jpg   New flush fin windows, recessed stucco arch above old frame-2011-11-23_15-33-15_535.jpg
thunder550 is offline   Reply With Quote
Old 11-28-2011, 08:39 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,742
Furr out that added depth with a piece of synthetic lumber or foam prior to apply the frame jump window and sealant.
I would still recommend a kerf cut into the stucco and a drip cap above the new window.
Old 11-29-2011, 01:29 PM   #3
Rewards Points: 14
Sounds good, will report back once it's done. Thanks! Should be another week or two before the window shows up.
Old 11-30-2011, 07:01 AM   #4
Tom Struble's Avatar
Rewards Points: 2,002
unless you get the vertical leg of the drip cap up under the paper what good is it?
to effectively install a drip cap under stucco you need to make a score cut a few inches above the opening,taking care not to cut the mesh,then carefully clean the old stucco off the wire
this makes it much easier to properly flash the opening and get a good key for a stucco patch
Tom Struble is offline   Reply With Quote
Old 11-30-2011, 07:48 AM   #5
I agree, however, the drip cap in this capacity is not intended to handle any of the moisture behind the stucco like a real drip edge would.
These type of stucco flange windows rely on a single caulk joint at the heat of the window to keep out any water that flows down the front of the stucco from getting behind the window. He is leaving the entire frame of the old unit intact. I was merely recommended another layer of water management to shed the water that is running down the front face of the stucco.
For the record, I prefer your method but based on the customers feedback, I am not sure he is going to go that full blown route. We have done jobs like these and just cut the stucco back and applied 5/4 azek in lieu of the patch once the stucco was removed in the exact footprint of the azek.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Tom Struble (11-30-2011)
Crack between aluminum window frame and stucco? jrleek Building & Construction 8 11-14-2011 02:13 AM
eyebrow arch on enclosed stucco patio stobin Building & Construction 2 01-31-2011 04:33 PM
replacement windows in stucco houser Building & Construction 3 08-22-2007 11:28 PM
Replacing "Aluminum Flared" Windows? bahaisamurai Building & Construction 6 06-07-2007 10:23 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
