New Entry Door + Old House = Grrrr
1 Attachment(s)
I wanted to upgrade our outdated entry door with a new prehung entry door from Lowes or Home Depot. I'm a newer home owner with little construction experience but I like to get my hands dirty. I have replaced our windows with new prehung windows so I figured this project would be similar.
First off, the house was built in 1927 and as far as I can tell this was the original door opening. I pulled the trim off around the interior of the door to see what we were working with. I went to measure the rough opening and bam I ran into issues from the get go. I don't see studs and the width is wacky 33 3/4. I was expecting to see some studs so I tried drilling a couple of little holes around the perimeter to see if the plaster was covering it but I'm not hitting any wood. Has anybody seen this before? What would you do if you were me? Is the 3/4 inch framing around the door sufficient for a pocket door? Should I just go ahead and order a custom size? Should I just put the trim back on and give up? Should I shell out the $$ for a pro? Any idea what the damage would be on something like that? |
Hard to tell from that picture what I'm even seeing.
Looks like a door, the jamb then the 2 X 4 above it. Let us know what the measurement of the door are, not the rough opening at this time. The rough opening should be about 2" wider the the door and from 1" to 2" taller. |
Door Measurements
Sorry, my pictures aren't uploading. What did upload was a sideways shot of the hinge and the hole I drilled to see if I would hit stud. Disregard my rough opening measurement from before:
Door Height 81.5 Door Width 33.5 to 33 3/4 |
1 Attachment(s)
Here is the interior of the door.
I am hoping to hire a pro who has seen this before. Maybe he can figure a way to insert a stud inside the outer edge of the box somehow? (Just sympathizing and hoping for some responses. ;) ) |
What is measurement of the door hight and width?
Then also, what exterior siding do you have outside? We can figure this out, just need right info. |
He gave the door size already.
But I wonder if that height was not including the threshold. To the O/P is that the real size of the door or did you measure from the floor to the top of the door? A normal door would be 80" that why I ask. |
Could be when you drilled the hole and didn't hit wood was maybe there was shims and you just missed them.
It was common to find no headers and no king and jack studs in older houses in the window and door frames.
If you really want to use a prehung door someone's going to have to open up that wall and also deal with some of the outside trim. If I went to that extent I for sure would change it to a 36" door. Another option is to just buy a slab door and cut it to fit in the same frame you have now. |
I feel your pain....our house was built in 1952.....tried to replace the side door....width was 'more or less standard'.....but the height was 2" more.....ordered a custom door from Lowes....got a standard sized door.......
As Joe said....your going to have to open up that wall......and when he says open it up....he means 'open it up'.....don't try to save yourself some work by only cutting back as much as you 'think' you need to...cut all the way to the ceiling....and on the sides....try to find the next stud and cut back to there. |
until you pull the "whole" door out, you are not going to know what you are dealing with.
The rough framing around your door should not be right against your jambs, so its no surprise that your holes hit nothing. You have a 34" width, which while uncommon, is somewhat of a standard size (although that does not mean that you can buy one off the shelf). On the height, as Joe alluded to, we need to know exactly where you are taking that measurement from. If you have an RO of 82"+, you will be fine with a standard height door. Many homes of that age have either smaller (79") or larger (84") doors, so make sure that you are measuring properly.
My advice on how to proceed: hire a pro. Doors are tricky enough to get right as it is, the last thing that you want is a door ordered wrong or some major installation hassles. That said, I realize that this is a DIY board, so my best advice to that end would be to make sure that you have accurate measurements. Even the simplest installs can become absolute nightmares if not measures correctly. |
In old houses like this I try to save myself some work and having to deal with air leaks and wood rot later on.
I order a door with an adjustable sill, I know the floors not going to be level or flat so this makes up for that. I also prefure to to get at least the rot free style, it's PVC lumber finger joined at the bottoms of the jambs and brick moulding. Better yet but more expencive is soild PVC jambs and brick moulding. No painting, no rot and the jambs stronger then a wooden one when it comes to a break in. |
So I measured three times the height of the actual door. I did the middle and edges to make sure it was correct and I'm getting 81.5 each time. This is the actual door size.
Still not a big issue if you have wood siding and wood trim outside.
We call it hammer it to fit and paint it to match. Still may want to find someone that's worked on older homes and not just new constrution. Totaly differant ways of thinking. |
| All times are GMT -4. The time now is 06:26 AM. |
