New Door Installation Question - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 06:36 PM   #1
mrs fix it's Avatar
new door installation question
I hope this isn't to stupid a question, but how deep is a new door supposed to be? Had a new door framed in a new spot near the old one. reason for my question is the placement of the stud when I screw in the new deadbolt, I,m afraid it won't hit the stud enough. I took photos hope that helps.
This door goes from my kitchen to the garage if that makes any difference.
Thanks in advance.
mrs fix it is offline   Reply With Quote
Old 11-30-2011, 07:53 PM   #2
A door a day is all I ask
TheDoorGuy's Avatar
What manufacturer is that deadbolt? If it is Schlage, Emtek or Baldwin it should come with a reinforcing
plate that fits in under the satin nickel trim plate. It's about 1/8" thick and has holes off to the side
for the larger screws that secure the plate to the stud. From your picture through the receiving hole (nice shot btw!),
it looks like it should catch the stud nicely. If you are still concerned you could glue and screw a block of
wood to the stud where it will be covered by the casing after drywall. That would give you a little extra meat to hold screws.
Best of luck with the project!!
RC/DG
Richard The Door Guy
www.thedoorguy.com
TheDoorGuy is offline   Reply With Quote
Old 11-30-2011, 09:54 PM   #3
mrs fix it's Avatar
I am installing the knobs, yes it has plate but I have to use the chisel to make the hole. Yes it's a Shlage, amdahl thanks for the coment on the photo.
I wasn't going to try screwing deadbolt plate in place till I knew I could safety.
Old 11-30-2011, 10:26 PM   #4
TheDoorGuy's Avatar
A couple of little things that should help:
1. I see that you have a shim above the deadbolt strike plate area.
Shim just below the hole also so that the bottom screw does not pull your jamb away from door.
2. Drill a pilot hole for those big security screws. 3/16" or slightly smaller bit should work well.
If you don't you might split the jamb or the screw could get stuck going into the stud.
RC/DG
www.thedoorguy.com
The Following User Says Thank You to TheDoorGuy For This Useful Post:
Windows on Wash (12-01-2011)
Old 12-01-2011, 08:59 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 842
You won't get much better advice than Richard just hooked you up with.
BTW Richard, I look at some of your portfolio work...
Really nice stuff. I wish you were out on this coast.
The Following User Says Thank You to Windows on Wash For This Useful Post:
TheDoorGuy (12-02-2011)
Old 12-01-2011, 10:59 AM   #6
mrs fix it's Avatar
Thank you for the advice, we will get right to it, right after my husband and I get over having the flu. Yuck!
Old 12-02-2011, 09:00 AM   #7
TheDoorGuy's Avatar
Thanks for the kind words, Win!
RC/DG
www.thedoorguy.com
Old 12-03-2011, 11:18 PM   #8
Rewards Points: 154
a question for you guys do you shim the top of the door?
awdblazer is offline   Reply With Quote
Old 12-04-2011, 12:26 AM   #9
TheDoorGuy's Avatar
Do you mean do I shim the head jamb?
If so, I say yes, as needed to straighten reveal.
RC/DG
www.thedoorguy.com
Old 12-04-2011, 01:07 AM   #10
Rewards Points: 154
my reveal is good, just wondering cause it is just a 1/2 inch gap
Old 12-04-2011, 09:19 AM   #11
TheDoorGuy's Avatar
Where is the 1/2" gap that you mentioned?
If it is between the header and the jamb, just make sure that
it is shimmed and nailed securely and fill with door and window low expansion
spray foam..
Do not overfill because it is very sticky and messy to clean up!
Acetone on a rag cuts it pretty nicely as long as it is not dry yet.
Then proceed with flashing and exterior and interior finish work.
I hope that answers but am not sure that I understood question!
RC/DG
www.thedoorguy.com
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
