New Construction Windows In An Old House - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-22-2012, 02:46 PM   #16
Haverhill Trade 1965
I am a little confused when you say there is no sheathing. In the next to last picture it looks like horizontal boards on the outside of the studs but in your first two pictures the siding looks vertical. Some looks like T1-11 and some looks like tongue and groove pine. Two layers or one would be treated differently. If there are two layers it would be easier to cut the trim into the first layer to cover the flange, and drip cap at the top is easier.
Duckweather is offline   Reply With Quote
Old 08-22-2012, 08:52 PM   #17
The first two pics are mine: website rotated pics, siding is horizontal. Last two pics are not my post. I have no sheathing, only solid redwood siding.
homehobby is offline   Reply With Quote
Old 08-23-2012, 04:50 PM   #18
OK, Now I understand. My first post about T1-11 would still be the proper procedure, as the siding was applied in the same way. It isn't according to Hoyle but it works. It also leaves you with the option of siding over the existing siding, up to the new window casing, and using drip edge at the top.
Old 08-26-2012, 04:02 PM   #19
Thanks Duckweather. I put one window in over the weekend. Looks great and easy enough to seal it up.
FYI. To remove old aluminum window I removed the glass then used a crowbar to remove the frame. Took some brute force but managed to remove without and damage to RO or siding. A sawzall helped too.
Front windows leaking dengle Windows and Doors 52 03-12-2012 10:54 AM
House Under Construction ... with moisture problems !!! ken338 Insulation 8 03-11-2012 08:52 PM
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 12:39 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Buying New Windows on an old House water_cutter101 Building & Construction 1 02-27-2008 04:10 PM
