New Construction Windows In An Old House - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-19-2012, 10:51 PM   #1
new construction windows in an old house
Hello. I am going to be putting some new construction windows in an old house. I will be removing the aluminum window frames and wood frame down to the rough opening. The nailing flange in the old windows is nailed directly to the studs with the siding overlapping the flange. There is no plywood sheathing. My questions is: what is the best way to install the new windows? Should I nail the new flange to the siding and flash over the top? Or should i cut back some of the siding and nail the flange to the studs as was done previously? Should i try to remove the siding and replace over the flange? Thanks.
homehobby is offline   Reply With Quote
Old 08-19-2012, 11:50 PM   #2
Rewards Points: 12,876
Posting a picture is always nice.
Is this a wood sided home?
Why are you installing new constrution Instead of replacement windows?
Old 08-20-2012, 10:10 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
for a new construction window you will have to treat it as new construction and remove any siding in the way of installing the window and then re-side tight to the window sealing everything up.
hand drive is offline   Reply With Quote
Old 08-20-2012, 10:01 PM   #4
Rewards Points: 166
in my old house. the rough opening for the windows is not even close to the size of the window. you "may" have to do some framing.
Fix'n it is offline   Reply With Quote
Old 08-20-2012, 10:44 PM   #5
Fixnit did you order the windows to size or just buy off the shelve?
Wondering why yours were so far off. All the windows I buy are made to the size I ask for.
Old 08-20-2012, 10:54 PM   #6
it is a wood sided house. no sheathing underneath. so the consensus is to remove the siding enough to nail the flange to the framing and put siding back up to window? seems like alot of work to remove that much siding, and costly. what is wrong with nailing flange directly to siding and using flashing tape and well-caulked trim?
Old 08-20-2012, 11:13 PM   #7
How would you fill in 1/2 gaps every 5" or so?
The top and bottom pieces would be sitting at an angle so you would have to shim them to sit flat.
Now a great way to do it.
Old 08-20-2012, 11:34 PM   #8
AHH, SPANS!!!
When you plan to pull the old windows how will you pull the flange from behind the siding? is there brickmolding or any other type of exterior window trim around the windows ?
Old 08-20-2012, 11:39 PM   #9
Without some pictures everyones going to just be guessing all day long.
Old 08-21-2012, 03:49 PM   #10
Thanks for the suggestions. I'll post pics tonight.
Old 08-21-2012, 04:31 PM   #11
Rewards Points: 150
You can take a metal sawzall blade and cut through 1 side, hammer claw those 2 peices out then claw the top down the bottom up and pry the other side out once bottom and top are gone.
But that doesnt help you install the new ones lol
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
The Following User Says Thank You to Hammer450R For This Useful Post:
homehobby (08-21-2012)
Old 08-21-2012, 09:35 PM   #12
pics included
Ok, some pics are attached: i have removed one side of the trim for better viewing of the situation. bottom line is siding is directly attached to framing. it is an old house so i dont think there is house wrap or flashing, just some caulking.
Regarding removal, one window has the flange outside the siding so it is easy to remove. the other window will take some work. thanks to hammer450 for the suggestion...
Regarding installation, is there anyway to do this without removing siding?
Here is a thread with some tips to waterproof directly to the siding: link
thanks for all your tips, i am obviously new at this but love the challenge!
new construction windows in an old house-photo.jpg   new construction windows in an old house-photo-1-.jpg
Old 08-21-2012, 09:36 PM   #13
sorry, link didn't work and pics are rotated the wrong way, but hopefully you get the picture (haha)
try: www.houserepairtalk dot com/f10/how-flash-mount-new-window-install-only-t1-11-siding-no-sheathing-6130/
copy address to browser (and replace "dot" with ".") sorry, I can't seem to link directly.
Old 08-21-2012, 10:04 PM   #14
Haverhill Trade 1965
That appears to be texture 1-11, siding & sheathing at once. My guess is that this was an unheated camp. Maybe use the window as a guide for the small side of the circular saw table, cut all around & remove old window. install new window, put a thinner strip into the cutout and case over it. I would use calk at every joint and all back edges of casing. Best caulking is elastomeric. OSI, True value has one, Agent Orange has one made by Dap but not sure of the name. All have a flammable warning. If not it isn't elastomeric. Those holes from the grooves MUST be calked to make watertight and keep ants out. sometimes you can make a saw cut in the siding at the top and get a piece of drip cap in, but it isn't easy.
Duckweather is offline   Reply With Quote
Old 08-21-2012, 10:15 PM   #15
Rewards Points: 166
i special ordered "minimum egress" sized sliders, cocoa, 52"w x 45"w.
they seems kinda large when i was measuring for them. but now that one is in, they are a great size.
anyway. the old windows were narrow and tall. i couldn't put ANY furniture in front of them, they were so low to the floor. i wanted what i wanted, so i framed the RO for the new windows.
i just today moved my office into this room. as saturday i have a crew coming over to demo the office room
pic 1 is the office . a mirror of this room.
pic 2 is this room, all stripped except the original window. you can see how the RO is a lot larger than the window.
pic 3 new window installed and drywalled, but not finished.
new construction windows in an old house-img_1813.jpg   new construction windows in an old house-img_1804.jpg   new construction windows in an old house-img_1814.jpg
Front windows leaking dengle Windows and Doors 52 03-12-2012 11:54 AM
House Under Construction ... with moisture problems !!! ken338 Insulation 8 03-11-2012 09:52 PM
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 01:39 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Buying New Windows on an old House water_cutter101 Building & Construction 1 02-27-2008 05:10 PM
