New Construction Windows And Gaps Sealing - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-04-2015, 09:18 PM   #1
Rewards Points: 93
Question
New construction windows and gaps sealing
Hi guys,
We have a small kiln-dried log cabin construction in-flight. It's under roof now. I asked builder how he's gonna seal gaps between log and window frame. He said he plans on stuffing as much insulation as he can and trim around, inside and outside.
My question is if I'd be better of using low expanding foam in place of insulation? When I asked him this same question he said "Foam expands it puts unneeded pressure on windows, which can lead to problems opening and closing". I thought low expanding type of foam was supposed to fix that problem.
I'd really appreciate your suggestion. I would even do it myself if I need be.
Thanks in advance.
SM05 is offline   Reply With Quote
Old 07-04-2015, 10:17 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,368
Low pressure window and door foam is just that...low pressure.
It will not create operation issues for your windows if it is used properly.
Don't try to seal larger gaps in one pass.
The Following User Says Thank You to Windows on Wash For This Useful Post:
SM05 (07-05-2015)
Old 07-05-2015, 06:34 AM   #3
Rewards Points: 4,636
And compressed fiberglass insulation "jammed" in there does nothing, may as well stuff in an old sock.
SM05 (07-05-2015)
Old 07-05-2015, 10:24 AM   #4
Rewards Points: 93
Great. Most of the gaps there are rather wide at about 1" or so. I can do a 1/2" pass at a time letting it harden while working on another window. And then do a final pass to seal it off.
Thanks.
Old 07-05-2015, 10:38 AM   #5
+1
Do smaller passes. Spritzing the opening with a mist of water will make the foam cure faster if we don't have any humidity but there is plenty of that in the air right now.
Be sure to not foam the bottom all the way to the backside of the flange or you will block the drainage. You only foam the bottom about midway deep on the window so that you get air seal.
SM05 (07-05-2015)
Old 07-05-2015, 10:53 AM   #6
Rewards Points: 93
Thanks for the bottom piece suggestion. Makes sense. Thanks for your help.
Old 07-05-2015, 03:05 PM   #7
That's a huge gap.
If it was mine I'd start with wide gap foam for the first pass.
Old 07-05-2015, 05:45 PM   #8
Rewards Points: 93
Originally Posted by joecaption View Post
That's a huge gap.
Wouldn't wide gap foam be hard to control? In another words, wouldn't it expand to cover the entire gap pretty rapidly?
Sealing Replacement Windows mystic_cobra Windows and Doors 3 05-15-2015 04:45 PM
Sealing Replacement Windows Pittsville Windows and Doors 22 07-15-2011 03:04 PM
Replacing Windows... How Do I seal the Outside Gaps? yamster Windows and Doors 19 06-20-2011 09:17 PM
Sealing around replacement windows VersaBar Building & Construction 1 12-01-2010 11:28 AM
Sealing Windows DIY_JC Building & Construction 1 09-13-2009 02:04 PM
