| Just Bill |
04-13-2011 08:21 AM |
When in doubt, always follow manufacturers directions. I do it both ways, on the sill and spaced. If the sill plate is not level, you have no choice. But setting it up will keep it out of water should the window leak. And don't forget to install a sill shield for leak protection. Nail tightly, but not overly so. Caulk the nail fin, then install self stick flashing starting at the bottom, sides, top. Aluminum flashing on top up under house wrap, and down over the window.
