New Construction Window Bow/warp. Help - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-14-2012, 06:03 PM   #1
Building a new home through a home builder. Window brand PlyGem builder model. Framer installed the vinyl windows, worked fine until insulation guys sprayed a foam that expanded to much in which it cause all the single hung window to bow/warp. First time contractor used that foam brand, pink color. Windows are not opening and closing that easy now. Insulation guys scraped all the foam out then took out some nails on the window frame and tried to straighten it back out and renailed it. Then sparyed another foam in. Seems like the bow somewhat straighten out. Some look unleveled. Some windows still feels wierd when opening and closing. And one window they put 3 screws on each inside of the windows to straighten the window frame out.
Contacted Ply Gem windows and they said if the foam cause the window to bow it would void the warranty, which is 1 year, But Builder also has a 1 year warranty on the whole house. Should I be worried?
Original Post: http://www.contractortalk.com/f33/ne...p-help-119122/
typer0186 is offline   Reply With Quote
Old 06-14-2012, 06:58 PM   #2
Pure Genius
Rewards Points: 150
Make them replace them now and not later
Dierte is offline   Reply With Quote
The Following 2 Users Say Thank You to Dierte For This Useful Post:
Evstarr (06-14-2012), Tom Struble (06-14-2012)
Old 06-14-2012, 09:08 PM   #3
Just went to check them out. The framer took out the nails on one side of the windows and let it stretched out then nailed it back in. Now the windows move a lot better but 2 windows still have some resistance when opening and closing.
Then they sprayed some kind of lubricant on the window side jamb so it can slide more freely. One window still have 6 screws in the side jamb still because it was bow pretty bad. Should I ask only to replace the windows that still have resistance to them? and of course the one with the screws.
Old 06-14-2012, 09:30 PM   #4
This is what it looks like after they took out the nails to re-nail them. Here is some of the pictures. What would you do?
Old 06-14-2012, 09:57 PM   #5
Some pictures when they took out some nails.
Old 06-14-2012, 11:59 PM   #6
This ^^
They screwed up. You are not their guinea pig. Unless there is a significant financial incentive to you, make them fix it right at this time.
Evstarr is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
New construction Window Advice bill19765 Building & Construction 2 11-07-2009 09:12 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
RO size vs. window unit size, new construction BigJimmy Building & Construction 3 01-02-2008 08:34 AM
