New Construction Measurment - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 11:17 AM   #1
Rewards Points: 878
Ok, almost there guys...just have to order it. As I am sure you know my extg. window is about 33x53 and I am replacing it with a bigger window. I am buying the Softlite Barington and they guy asked for the measurements. If we want the actual window(viewing area) 45"Wx 55" what measurements would I give him? Slightly bigger? Idk if the measurements they require are flange to flange etc. The new frame and header is not built yet. Thanks.
Mstrlucky74 is offline   Reply With Quote
Old 02-27-2013, 12:01 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I would strongly recommend discussing this with your installer, as he is the one that will be doing the framing. You can get the measurement from the edge of the frame to the glass from Softlite and provide it to him, and you guys can then decide what makes the most sense given the location of the window and the glass measurement that you desire.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-27-2013, 05:34 PM   #3
Rewards Points: 878
Thanks HS...as always. Had another guy come give me an estimate today....looks like the $300-400 range is correct. He said the measurement going wider really would not make a difference whether we wanted 43" or 46". He did suggest that I don't go much higher than the extg. Window which is 53". He said the header would be load bearing and would more tha likely be a 2x6.. He said the Soflite Barington would be about 2" from edge of frame to glass
interior construction project question kindofsudden Building & Construction 5 11-07-2012 09:51 AM
Books that teach the basics of construction - recommend them to me? costafinkel Building & Construction 13 08-04-2011 11:32 PM
Soft Hearted Construction Guys Wildie Building & Construction 0 11-29-2010 06:05 PM
Construction Nightmare - need help!! naper_home Building & Construction 5 04-06-2006 03:57 PM
