#1 |
new const window
how do i measure window
#2 |
Exterior Construction
new const window
Stud to stud with 1/4" - 1/2" cut back on the width and height if the opening is square.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Experienced
new const window
Hello Bill and welcome to the best darn DIY'r site on the web.
I usually use a tape measure, but string works to...... ![]() Measure rough opening and give that to your window manufacturer of choice, make sure they know its the rough opening dimension you are giving them. Measure in a few locations in both directions to ensure you have noted the narrowest width and height. Edit,,,,,,Make sure you also measure to ensure the opening is square (corner to corner)! Mark
When its all said and done there is usually more said than done To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Jackofall1; 10-02-2012 at 05:23 PM. |
#4 |
journeyman carpenter
new const window
for a new construction window measure the roiugh opening.. the manufacturere should make the frame 1" less both in width and height so to allow for shimming and space for spray foam insulation.
if going retrofit you'd need a brick to brick measurement for the exterior trim. |
| Display Modes | |
| Actual size of new const. window frame?? | toolingaround | Building & Construction | 5 | 10-22-2010 11:59 PM |
| Defog window recap | greenmax | General Discussion | 4 | 05-07-2010 06:00 PM |
| help need to know how to replace windows wrapped in drywall | caide3 | Carpentry | 4 | 03-02-2010 01:41 PM |
| Problem with window and everything around it | malfunction | Building & Construction | 3 | 05-26-2009 06:11 PM |
