Need To Replace The Molding Inside And Outside Around An Arched Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-23-2012, 11:15 AM   #1
Landlord
Rewards Points: 89
Need to replace the molding inside and outside around an arched window
How do you get the molding to shape into an arc?
cocean is offline   Reply With Quote
Old 12-23-2012, 11:27 AM   #2
DIY staff
Rewards Points: 7,174
Most trim guys will take the arch profile to a millwork house and have the trim made on a molding shaper (planer) that can make the arched profile----Youtube videos on 'arched moldings' might give you an idea.
If you have a band saw and a router---a simple profile could be cut---but a detailed molding must be cut from the face---so a molding shaper (Planer) is needed---
Old 12-24-2012, 09:33 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,954
They make flexible PVC trim if you go that route that can either be hand or thermally formed.
If in wood, best bet is a millwork shop.
Old 12-24-2012, 09:38 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
Flex Trim
looks like rubber and requires lots of nails to install... cut long and fit it in as you go, you do not want to come up short with your cuts. Call a lumber supply and tell them the dimensions of the arch and the trim profile of your trim.
hand drive is offline   Reply With Quote
Old 12-24-2012, 10:03 AM   #5
Rewards Points: 13,300
http://flextrim.com/
