Need To Lower Deadbolt Hole For New Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-05-2013, 03:44 PM   #1
Rewards Points: 588
My dad bought a new door and everything matched up except the deadbolt lock. He needs to fill the original hole in the frame from the old door so he can put a new hole about an inch lower and have a way to screw down the striker plate. What's the best way to fill that hole so it can be screwed into?
We left the plate on until we can fix that hole.
nikeman is offline   Reply With Quote
Old 05-05-2013, 04:20 PM   #2
funfool's Avatar
Rewards Points: 534
I would first move it down and get the hole working.
Honestly 1" sounds like a lot, are you sure you are not exaggerating and needs to go down a 1/4 or 1/2 inch?
Make it work and then show a photo of what needs repaired.
Durhams rock hard water putty must be a 100 years old, still something I carry on my truck,
funfool is offline   Reply With Quote
Old 05-05-2013, 04:24 PM   #3
kwikfishron's Avatar
Rewards Points: 170
I'd fill the hole with this. After it sets up sand it smooth and then drill the new hole. If the new hole is going to overlap the old I'd let the Durham's set overnight even though you could probably sand it after about a hour if you mix it right.
kwikfishron is offline   Reply With Quote
Old 05-05-2013, 04:29 PM   #4
Bondo auto body filler sets up fast and will last for ever. It is paintable, use a long screw that will screw into the stud.
Hardway is offline   Reply With Quote
Old 05-05-2013, 04:45 PM   #5
funfool's Avatar
Rewards Points: 534
still wondering if there is a light on the other side of style ... longer screws are good, but not always the best.
Old 05-05-2013, 05:15 PM   #6
Too Short? Cut it Again!
Abatron's epoxy wood filler will do the trick too.
Old 05-05-2013, 06:26 PM   #7
Rewards Points: 588
Thanks guys. I told my dad to look for the durham stuff at Home Depot. I think the area where the current hole is will be covered by the plate once we drill the new hole so painting isn't a huge issue.
Old 05-05-2013, 06:34 PM   #8
Rewards Points: 170
Any hardware store will have it. I't a powder you mix with water, just don't mix it to thin (follow the directions), it's good stuff (and cheap too).
Old 05-05-2013, 06:56 PM   #9
Rewards Points: 588
Home Depot has it for $2 I think.
Patching a hole in an exterior door Iron Petunia Windows and Doors 0 10-24-2011 03:14 PM
how to fix hole in porch door jamb? bublsort Windows and Doors 4 10-23-2011 04:14 PM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 07:50 AM
Door Knob Hole Cover Plate One Side ice Carpentry 5 06-30-2011 02:18 PM
Entry Door Size han Building & Construction 5 08-20-2009 08:54 AM
