-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Need to lower deadbolt hole for new door (http://www.diychatroom.com/f104/need-lower-deadbolt-hole-new-door-178836/)
nikeman 05-05-2013 03:44 PM
201 Attachment(s)
My dad bought a new door and everything matched up except the deadbolt lock. He needs to fill the original hole in the frame from the old door so he can put a new hole about an inch lower and have a way to screw down the striker plate. What's the best way to fill that hole so it can be screwed into?
We left the plate on until we can fix that hole.
Attachment 70398
funfool 05-05-2013 04:20 PM
I would first move it down and get the hole working.
Honestly 1" sounds like a lot, are you sure you are not exaggerating and needs to go down a 1/4 or 1/2 inch?
Make it work and then show a photo of what needs repaired.
Durhams rock hard water putty must be a 100 years old, still something I carry on my truck,
kwikfishron 05-05-2013 04:24 PM
199 Attachment(s)
I'd fill the hole with this. After it sets up sand it smooth and then drill the new hole. If the new hole is going to overlap the old I'd let the Durham's set overnight even though you could probably sand it after about a hour if you mix it right.
Hardway 05-05-2013 04:29 PM
Bondo auto body filler sets up fast and will last for ever. It is paintable, use a long screw that will screw into the stud.
funfool 05-05-2013 04:45 PM
still wondering if there is a light on the other side of style ... longer screws are good, but not always the best.
user1007 05-05-2013 05:15 PM
Abatron's epoxy wood filler will do the trick too.
nikeman 05-05-2013 06:26 PM
201 Attachment(s)
Thanks guys. I told my dad to look for the durham stuff at Home Depot. I think the area where the current hole is will be covered by the plate once we drill the new hole so painting isn't a huge issue.
kwikfishron 05-05-2013 06:34 PM
199 Attachment(s)
Any hardware store will have it. I't a powder you mix with water, just don't mix it to thin (follow the directions), it's good stuff (and cheap too).
nikeman 05-05-2013 06:56 PM
201 Attachment(s)
Home Depot has it for $2 I think.
