Need Help With Wood Double Hung Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-26-2013, 10:51 PM   #1
Need help with wood double hung windows
Our house was built in 1986 and has original wood double hung windows. We are in the process of selling and I want to be sure all windows are operable. Today I had to free a stuck top sash which had been painted. When I finally got it to move, two "clips" (for lack of a better word) fell out of holes in the bottom of the upper sash. I have included a photo. I dont know what these are or how to get them back in place. Please help!
lawyer101 is offline   Reply With Quote
Old 12-26-2013, 10:57 PM   #2
Rewards Points: 150
no pics, but they might hold the springs in the ballast boxes that help to hold and move the sash up and down????
hpyjack2013 is offline   Reply With Quote
Old 12-27-2013, 02:46 AM   #3
Trying again with Pic
Not sure what happened to the pic -- trying again. thanks!
Old 12-27-2013, 08:27 AM   #4
Rewards Points: 150
I pretty sure that's what those are. They go through a spring and then into a space on the bottom of the sash to keep tension on the springs to help the sah go up and down . can you see the bottom of the sash? any imprint in the paint or finish?
Old 12-27-2013, 08:41 AM   #5
Yes, there is a "hole" for lack of a better word where this clip fits in on the bottom of the sash. The channel for the spring is inside there. Looks like part of this clip may also fit into the track the window slides on?
How do reconnect this, and where can I buy more if I need them?
Thanks!
Old 12-27-2013, 08:48 AM   #6
Rewards Points: 150
examine the clip and see if the piece or notch that the spring connects to isn't broken off. If it is your going to have to find new ones. Think of where the contractor that built your home might have bought the windows and start there. your going to have to try and hook the spring and draw it below the sash to re-install clips. It might take a little bit of work. can you see the springs inside the balance or ballast?
The Following User Says Thank You to hpyjack2013 For This Useful Post:
Windows on Wash (12-27-2013)
Window Blinds for Double Hung Windows (2") 7 VII 7 Interior Decorating 8 07-09-2013 09:12 PM
Double windows lonerinalaska Windows and Doors 3 08-16-2012 05:32 PM
vinyl double hung replacement windows beefaroni11560 Windows and Doors 6 07-31-2011 12:36 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 03:24 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
