Need Help Storm Door Hard To Close - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-09-2012, 06:58 PM   #1
Need help storm door hard to close
Over a year ago I had a new storm door put in.
Now whenever I close it have to have to slam it a couple times to make it shut.
I kid of hits the door frame on the open side.
Any idea whats wrong or how to fix it?
thank you
jealousblues is offline   Reply With Quote
Old 05-09-2012, 08:44 PM   #2
Rewards Points: 6,652
You have to adjust the set screw in the back of the closer to adjust the pressure for the piston.
Old 05-09-2012, 08:50 PM   #3
Rewards Points: 12,882
Is there a safety chain on the door? If not also look at the shaft on the piston to see if it's bent.
There should a philips head screw on the piston that can be adjusted. Unscrew it a little at a time and test it. Lefty loosey.
Old 05-09-2012, 09:35 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 710
If it is hitting on the latch side, adjusting the closer will not help. Take a level and see if the hinge sides z bar is plumb. If not, remove the face screws from the upper half and suck it over by tightening the return side screw, then re-install the face screws in the new location. If the hinge side is good, then you need to simply re-hang the latch side z bar. Take out all the screws, close the door, and fasten when you have a nice, consistent reveal from top to bottom.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
oh'mike (05-16-2012)
Old 05-10-2012, 08:00 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
+1
Here is a picture of HomeSealed working on a storm door in just such a manner.
The Following User Says Thank You to Windows on Wash For This Useful Post:
HomeSealed (05-10-2012)
Old 05-10-2012, 09:25 AM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Red is my best color.
www.HomeSealed.com
Old 05-10-2012, 11:34 PM   #7
Thanks for the help so far guys.
Heres an update
I checked it today and its hitting towards the top of the door on the side of the jam.
When I lifted on the handle it worked better.
Does this change any advice you have given?
Im not too knowledgable on this stuff so im clueless and learning as I go along.
Old 05-11-2012, 01:08 AM   #8
DIY Enthusiast
sublime2's Avatar
Heres an update
If you lifted the door slightly by the handle and it closed better,the odds are the screws on the hinge side of the door need to be tightened. The ones that attach the door to the hinge or the hinge frame itself.
You may even need to replace them with longer ones to grab and hold on the hinge frame.
sublime2 is offline   Reply With Quote
Old 05-16-2012, 07:56 PM   #9
thanks guys, its working great now
Old 05-16-2012, 08:00 PM   #10
Tom Struble's Avatar
Rewards Points: 2,002
is ''suck it over'' a technical term?
Tom Struble is offline   Reply With Quote
Old 05-16-2012, 08:07 PM   #11
kwikfishron's Avatar
Rewards Points: 92
Of course it is...You must have skipped school that day.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Tom Struble (05-16-2012)
Old 05-16-2012, 11:46 PM   #12
Home Performance
HomeSealed's Avatar
Rewards Points: 710
some take it more literally than others!
www.HomeSealed.com
packer_rich (05-17-2012)
How to get double front doors to close tight Advising Elf Windows and Doors 31 12-30-2012 12:09 PM
Front Storm Door Won't Latch sciron General DIY Discussions 6 02-21-2011 10:47 AM
Storm Door Selection/Brand Advice Wanted kc27 General DIY Discussions 3 10-25-2009 09:17 AM
Storm Door Handle Installation jogan General DIY Discussions 3 06-09-2009 10:57 PM
Storm door replacement Davidb6 Carpentry 10 05-18-2009 10:40 AM
