Need Help With Replacement Window Size Urgently - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-24-2012, 10:40 AM   #1
Need Help with replacement window size Urgently
I have 5 windows i need to get replaced. All are on the second floor. The measurements for the replacement window sizes that i can fit in there are 24w x 45h but the closest windows i can find that are 9 inches shorter than what i need. How can i put replacement windows in when i have to make up the 9 inch gap in there? Im a renter and my landlord is a cheap @$$ and doesnt wanna pay an actual window company to replace them so and doesnt wanna pay a butt load for custom sized windows either. Is there anything i can do?
windowlost is offline   Reply With Quote
Old 04-24-2012, 12:59 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,634
Custom sized windows are not that expensive and in most cases are the same cost as a stock sized unit.
Old 04-24-2012, 01:04 PM   #3
Rewards Points: 13,712
Almost all replacement windows are made to size, not even sure how places like Lowes and HD can sell them, I've never once found one on the shelf the right size.
The landlord is paying for these, right?
Old 04-26-2012, 12:31 AM   #4
Registered User
Rewards Points: 5,514
You do realize you will be liable for any windows you install? Water leaks, breakage at install, egress sized for bedrooms, etc....
Gary
P.S. Welcome to the forums!
Why are replacement window frames so wide? twobyfour2 Windows and Doors 8 07-06-2011 06:56 AM
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
Install replacement window while keeping new construction window in place key1cc Windows and Doors 9 03-25-2011 08:15 AM
Basement window replacement Atskodinski Building & Construction 9 03-21-2011 03:26 PM
Window replacement procedures Mudball Building & Construction 3 02-21-2010 08:36 PM
