Need Help Removing Patio Door - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-19-2013, 07:08 AM   #16
If you want to remove the door, slide a flat blade under the door and lift to remove to free the roller of weight. With the help of another screwdriver adjust the screw. Now the door will slide easily.
Door closers India | Fire Door hardware
Sridhar Raj is offline   Reply With Quote
Old 03-19-2013, 11:02 AM   #17
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Originally Posted by 747 View Post
I would lift door straight up. Then have somebody get down on there knees and see if they can lift those wheels up with a screwdriver or something. The wheels should be spring loaded. If you get one up then pull the bottom out and work on the other. May work or may not.
That is true for most rolling screens, but not the actual operating panel of the door (regarding springs). The wheels of the operating panel are mechanically adjusted.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
interesting patio door problems....please help. diybrad Building & Construction 6 11-20-2011 11:52 PM
Pella Patio Door Problem bad1129 Building & Construction 3 09-23-2011 05:29 AM
leaking patio door jpg274 Building & Construction 2 10-30-2009 03:42 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 03:19 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
