Need Help Installing A Window Stool - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 07:22 PM   #1
Rewards Points: 12
Need help installing a window stool
Ok, we had a dining room that was all thick wood paneling that had to be crowbarred out. In the process, I destroyed the window stools/sills inside. I have never done a window before so I don't exactly know how they are structured. Here is a photo of the entire window as it stands now:
Here's a close-up of what used to be the sill.
It also had a peice layered above it, which you can see in the right window.
So I guess my question is what to do with this shattered/splintered piece. Is that the remainder of the stool or actually part of the window frame? Does it need to be removed? Anyone have any good websites showing how to replace or install a stool?
king kork is offline   Reply With Quote
Old 02-27-2012, 07:29 PM   #2
DIY staff
Rewards Points: 7,174
Could you resize the picture?
Old 02-27-2012, 07:30 PM   #3
Rewards Points: 12
I just did - sorry. Didn't realize they were so huge.
Old 02-27-2012, 07:41 PM   #4
Rewards Points: 12,794
That's going to be fun. You have broken off what you need to attach the stool to.
I would use a Toe kick Saw to cut it even with the wall and add a jamb extention so you will have something to attach it to.
king kork (02-27-2012)
Old 02-27-2012, 07:56 PM   #5
Rewards Points: 12
I think a toe kick saw may solve another issue I have around a doorway... i'll look in to that further. Thanks.
Old 02-27-2012, 08:04 PM   #6
Now that I look at it again you may have to pull the windows and reframe the bottom trim. Or use an ossilating saw and cut it out the trim flush with the window frame.
It's broken off behond the wall.
Did you learn anything about the right way to remove window trim?
Old 02-27-2012, 08:13 PM   #7
DIY staff
A multi tool will help you with that repair---Harbor Freight has a good one--
Can you raise the new sill so that it butts against the vinyl window?
That would be easy--
Tom Struble (02-27-2012)
Old 02-27-2012, 08:29 PM   #8
Rewards Points: 12
The existing one did butt up against the vinyl window. If you see that caulk line, that is what I cut. Are you saying to do something similar to what Joecaption said, to cut the existing piece flush to the wall and put a sill on top butted up against the window?
Thank you btw.
Old 02-27-2012, 08:37 PM   #9
Unless you add you cut it flush with the window fram and add a jamb extention to get it all back flush with the drywall what would you nail the stool to?
(the piece at the bottom of the window that sits horizontal is called a stool, the part under the window that's outside is called a stool.)
Old 02-27-2012, 08:44 PM   #10
Rewards Points: 12
I may not have taken the picture well, the piece there is currently fully extended past the drywall. I can cut it back to be even with the drywall and that would leave about an inch of wood to nail the stool to if i layed it on top. I'm not sure that's enough support but that's what I'd have.
Old 02-27-2012, 08:47 PM   #11
Tom Struble's Avatar
Rewards Points: 2,002
outside is a sill
cut back flush but why an extension on the stool Joe?
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
HomeSealed (02-27-2012)
Old 02-27-2012, 08:49 PM   #12
add an apron under the stool and your good to go
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
HomeSealed (02-27-2012), king kork (02-27-2012)
Old 02-27-2012, 09:02 PM   #13
Look close at the pictures. Looks like the bottom framing in a few spots is broken almost up to the window.
I'm thinking without a jamb extention to get the rough flush again with the rock the only thing that would be keeping it from tipping would be the aprion and in most cases it's only 1/2" thick.
I'm not suggesting extending the stool, just the rough framing to give it more surface area so it does not tip if someone leans on it.
I hope that makes since.
Old 02-27-2012, 09:17 PM   #14
it does thanks
Old 02-27-2012, 09:23 PM   #15
Rewards Points: 12
I can see what you are talking about now in the picture that I posted. I do not have less than 1" at any point. I am going to try to cut it flush to the sheet rock with a multi tool and then attempt to mount a stool on what's there.
I appreciate the help so much, everyone.
cutting installed window stool in place rasz Carpentry 4 10-30-2011 05:09 PM
Installing a new window gladrags Building & Construction 1 07-22-2011 12:14 PM
Installing window in stone wall nina09 Building & Construction 12 08-28-2009 01:03 PM
New and need help w/ window stool Fingersallacct4 Remodeling 3 08-27-2009 06:43 PM
window casing stool help? Images posted chinese_lover Carpentry 12 07-23-2008 10:04 AM
