Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 09-24-2012, 02:18 PM   #1
need help installing door sweep! screws won't go in
My roommate and I have recently purchased a metal door sweep to attach to the bottom of the door. I am unsure what my door is made of (it looks like wood on one side but the other side looks like metal and when I knock on it it sounds hollow). Using the drill, I tried putting the screws in the door (using different amounts of pressure each time) to no avail. The screws just won't go in! They seem to make a very small mark at first and then just stop going in. I've double checked that the drill is set to screw in the right direction, and I've tried using both the screws that came with the door sweep and different screws made to go into metal. What could I be doing wrong? Please help!
doitmyself89 is offline   Reply With Quote
Old 09-24-2012, 02:32 PM   #2
"Nail-Bender"
If the door sweep is being screwed into metal -
try pre-drilling the metal, with a drill size smaller than the diameter of the
screw -
Don't over-drive the screws.
rossfingal
rossfingal is offline   Reply With Quote
Old 09-24-2012, 02:37 PM   #3
If you drill a pilot hole it should work.
If it doesn't or you just want to give up on the screws, you can use some adhesive tape. 3M has some mounting tapes (double sided) that you could find at a hardware store and they are weather proof and permanent. Just make sure you have the height of the sweep right first because you won't be able to move it afterward.
NHtransplant is offline   Reply With Quote
Old 09-24-2012, 04:21 PM   #4
It is probably a metal door. Try a magnet to verify.
danpik is offline   Reply With Quote
Old 09-24-2012, 04:25 PM   #5
"Nail-Bender"
It's probably an aluminum door - magnets won't work.
It could be wood-grain on one side - that's why it looks like wood.
Old 09-24-2012, 05:38 PM   #6
Yeah, he's probably right. Ignore what I said.
Old 09-24-2012, 09:46 PM   #7
Just drill a pilot hole and it will work.
Unless you have self tapping screws you will never get them in without a hole.
Tags
door sweep, drill, metal, screws, wood
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 29 03-07-2013 04:17 PM
Cut Off Stripped or Broken Screws mdawson3k General Discussion 23 07-26-2011 08:07 AM
Installing Porcelain tile, complete guide? Total Sugar Flooring 5 03-07-2011 10:22 PM
trim head screws lament! wombosi Tools 3 02-22-2011 08:44 PM
Can I use deck screws with Hardibacker? spaceman spif Kitchen & Bath Remodeling 10 10-26-2010 03:11 PM
