Need Help Finding Window Part - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-02-2014, 07:59 AM   #1
Rewards Points: 18
Need help finding window part
I moved into a new house (new to us) a few weeks ago and a few of the double hung tilt wash windows needs some attention. The part that you put in first and goes into the counter balance (I think that's what they are on each side) a few of them are either broken or bent. Im assuming from the previous owner not knowing how to remove and re install the tilt wash windows. There is no brand names on the windows, and very few numbers. I have attached two pictures of the part that I need. (The picture shows a good one). They either have a 'R' or an 'L' on it for right and left. Ill also include a few numbers I found. Thanks guys, im hoping someone knows of where to find one of these.
Numbers from a few windows:
611105. K26TG
J20HD
E01 DB30 XHD
Need help finding window part-window2.jpg   Need help finding window part-windowpart.jpg
lmholmes11 is offline   Reply With Quote
Old 10-02-2014, 08:24 AM   #2
Rewards Points: 5,256
Look in the bottom right hand side of the glass to see if there's a company name.
Some etch there glass.
Old 10-03-2014, 07:45 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,614
Try these guys. I have found many a part from them.
http://www.blainewindow.com/index.php
Old 10-03-2014, 10:02 AM   #4
Man of many hats
wrangler's Avatar
Rewards Points: 312
I looked at a few sites for that pivot bar but could not find that particular one. If you post some pics of the the windows it may help in determining the manufacturer.
Man of many hats
wrangler is offline   Reply With Quote
Old 10-03-2014, 12:27 PM   #5
MarginallyQualified
Rewards Points: 2,414
I just found a window part I've been searching for.
The company is SWISCO and they have a LOT of stuff.
Maybe yours too.
Ordered this AM and it's already shipped.
Old 10-03-2014, 07:38 PM   #6
Rewards Points: 569
Maybe yours too.
...and with Swisco, you can mail them a picture of the part you need and they will try to identify it.
ChuckF. is online now   Reply With Quote
Old 05-13-2015, 12:39 PM   #7
Rewards Points: 20
I believe that is called a Cam Pivot ... They are handed (right and left). Strybuc has one similar, 62-651RH
allston513 is offline   Reply With Quote
Help with a Window Removal/Install anthony232 Windows and Doors 12 09-18-2013 04:39 PM
Pass Through Counter Top & Window Setup Questions miamicuse Building & Construction 6 05-25-2013 08:13 PM
Replacing old kitchen window with new construction window speedster1 Windows and Doors 2 06-29-2012 12:13 AM
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 07:15 AM
