Is It Necessary To Notch The Side Door Jambs For Setting The Header Piece? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-08-2013, 08:48 PM   #1
Rewards Points: 1,062
Question
Is it necessary to notch the side door jambs for setting the header piece?
I need to make my own door jambs from 1x lumber because I have a salvaged antique transom (the whole door is actually restored antique) and couldn't find pre-made ones at Lowes/HD that are long enough. I did notice that the regular sized ones had a notch on each side jamb to set the header piece. I was wondering what the advantage of that is over simply laying the header piece on top of the side pieces. I can probably make notches in my homemade jamb but it would be easier to avoid the trouble and just set it on top of the side jambs.
Can anyone elaborate on the need to make the notches?
Is it necessary to notch the side door jambs for setting the header piece?-jamb_notch.jpg
Tags
door jamb
Cutting Trim and Hanging Doors ws450r Carpentry 8 12-28-2010 02:54 AM
Garage Header rwbil Building & Construction 11 09-16-2010 11:50 AM
Timing for rebuilding of side entry: Help! navi_jen Remodeling 0 06-16-2010 10:02 AM
what size header for eve side garage doors? vtboy51 Building & Construction 6 02-18-2010 10:15 AM
Moving Header Supports Star Building & Construction 3 09-25-2005 12:50 AM
