Is It Necessary To Have A Locking Doorknob With A Deadbolt? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-25-2013, 04:18 PM   #1
Rewards Points: 308
Is it necessary to have a locking doorknob with a deadbolt?
Can I get away with just a deadbolt?
smokey847 is offline   Reply With Quote
Old 12-25-2013, 04:33 PM   #2
bbo
sure, all part of risk assessment.
bbo is offline   Reply With Quote
Old 12-25-2013, 04:58 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
. It's quote common to see only the dead bolt with the lock. Don't get overly concerned about how well the door locks. If someone wants in bad enough, they will get in. The more common points of entry are side/back doors and windows. One last thing on that door bolt. In most areas it's against code to have a deadbolt that requires a key on the inside.
The Following User Says Thank You to ddawg16 For This Useful Post:
oh'mike (12-27-2013)
Old 12-27-2013, 09:19 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Deadbolts are many times more secure than knob locks, so if I had to have only one, it would be a deadbolt. As far as "If someone wants in bad enough, they will get in.", that may have some truth to it, but if you make it difficult enough, that same person won't be willing to make all the noise and go to that much trouble to get in. The longer it takes a thief and the more noise they must make to get in, the more likely they are to get caught.
Old 12-27-2013, 05:21 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Or move on to the next house......
sublime2 is offline   Reply With Quote
Old 12-27-2013, 06:07 PM   #6
Rewards Points: 6,652
Locks are only made to keep honest people out. It is really up to you if you want both. If the door has two holes, just put in an electronic entry lock, that the deadbolt can be controlled by the keypad or key, and the regular lock set has no key lock.
The Following User Says Thank You to gregzoll For This Useful Post:
princelake (12-29-2013)
Old 12-27-2013, 06:08 PM   #7
Only if you use 2 1/2" or 3" screws to secure the plate into the studs, same with the hinges.
Otherwise, one swift kick on the door, and it is going to open, regardless of how cheap or expensive the lock is.
Old 12-28-2013, 08:13 PM   #8
Rewards Points: 62
strike plate is also good
bklynsoulja is online now   Reply With Quote
Old 12-28-2013, 08:29 PM   #9
Post a photo of what you have.
Hardway is offline   Reply With Quote
Old 12-29-2013, 06:07 PM   #10
Rewards Points: 308
It's just a standard wooden and glass door.
I'm replacing all the locks and knobs with oil rubbed bronze hardware.
Old 12-29-2013, 07:00 PM   #11
Having all of that glass, the locks do nothing more, than keep the honest people out. As for the Oil Rubbed Bronze, it should look okay on that door.
Old 12-29-2013, 08:22 PM   #12
concretemasonry's Avatar
Rewards Points: 2,652
After the concern, maybe I will start to think about locking my doors and windows when I am gone. The problem is, I do not know if I even have a key.
Obviously, paranoid people tend to attract attempts at theft, either because they imagine a treasure inside or just want a challenge.
About 10 years ago when I live in northern MI (200 miles from hell/Detroit) I left my home for a 3 or 4 day trip to SF,CA. When I came home I saw the front door was open and the screen door was closed by the closer. It did not look too inviting because it appeared the home was occupied.
Dick
concretemasonry is online now   Reply With Quote
Get a door handleset without deadbolt daluu Windows and Doors 1 01-25-2012 06:25 AM
installing a replacement doorknob gardengal Building & Construction 36 03-01-2011 08:13 PM
Deadbolt too large for deadbolt hole in frame? wysiwyg6000 General DIY Discussions 2 01-01-2010 10:06 AM
Tool to deepen deadbolt hole? darsunt Carpentry 5 07-18-2007 10:45 PM
Deadbolt suddenly won't retract Squeeealer Carpentry 1 07-14-2005 08:20 PM
