Name That Weatherstripping? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-26-2012, 05:01 PM   #1
funfool's Avatar
Rewards Points: 534
name that weatherstripping?
Yet another how to seal a french door .... on same page!
Again these doors were hung wrong to begin with, was a real mess.
The house is 20 years old, the original installer moved the door hinges down on the jamb side, out of the mortise, and did not re mortise new hinge location.
This cased the doors where they meet in the middle to be sealed at top, closer to the jamb side could see daylight. They leaked everywhere.
I spent a couple hours re hanging, had to cut the top at an angle, reset strikers, shim hinges ...
And operates and seals good now.
Problem I am having, is the old weather stripping is wore out and needs replaced.
The older doors use a very typical style weather stripping, see photo.
But the older style doors used a thinner less wide version. Today standard is 3/4" x 3/4"
This is 1/2" x about 5/8".
Everybody has the 3/4" and some even have thicker. I spent 2 hours driving around town looking for it ... and I did try the 3/4" and doors will not close with it installed.
If I look on line to order the weather stripping, is there a name or model # to look for?
Anyone have a better idea how to seal it?
funfool is offline   Reply With Quote
Old 12-31-2012, 12:07 PM   #2
funfool's Avatar
Rewards Points: 534
All I figured out is, is called kerf weather stripping.
But seems to be no industry standard in sizing that I found.
I already know is at least 3 sizes, I found 2 sizes on the internet ... while most does not even list a size. And when they do list it, I do not know what side they measure.
Still unsure of best way to seal the center style on stationary door., the kerf weather stripping is ripped loose 3" from the bottom of door.
Old 12-31-2012, 04:21 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,238
Do these guys have anything that works for you?
http://q-lon.net/
The Following User Says Thank You to Windows on Wash For This Useful Post:
funfool (01-01-2013)
Old 01-01-2013, 08:59 PM   #4
funfool's Avatar
Rewards Points: 534
Thank you. is what I have been looking for, but my google skills once again failed me.
I appreciate you taking the time to give me the link.
Old 01-02-2013, 08:38 AM   #5
Sounds good.
Good luck with it. They certainly should be able to point you in the right direction.
How to fix uneven gap between door and weatherstripping? Objectivist Carpentry 30 07-11-2015 01:06 PM
Patio Door Weatherstripping FlyingHammer Windows and Doors 3 01-06-2012 08:51 PM
Weatherstripping entry door to garage steppinthrax Windows and Doors 2 12-12-2011 11:28 AM
Replacing weatherstripping on Marvin wood casement windows giger123 Windows and Doors 5 05-09-2011 06:50 AM
weatherstripping door catmech General DIY Discussions 4 07-15-2009 02:54 PM
