Nailing Aluminum Flashing Before Caulking - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-29-2012, 12:22 PM   #16
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,682
+1 on the coil stock if it is uncoated on the back.
Many of the coil stocks are painted on both sides now. If that is the case, you should be fine.
Old 10-29-2012, 03:30 PM   #17
Rewards Points: 13,732
You would think so but that's not the case.
Try it and see what starts happening around where the nails go is. They act as a conductor, once it starts to fail the finish starts peeling off.
The boxes still say right on them not to do it.
Old 10-29-2012, 05:38 PM   #18
Coil nails are usually coated and stainless. I agree that its nota good idea but you can back caulk the trim and effectively glue it on.
Old 11-01-2012, 05:10 PM   #19
hohadcr's Avatar
Rewards Points: 316
The outside opening is a lot smaller than the inside opening. There are wooden framing on the vertical sides, which is hidden by bricks, looking from outside. The new windows are screwed in to the frames. on both right and left sides with 3 nails on each sides. The manufacturer provided the 6 screws for each new window.
I have found some companys here that are willing to sell me bended aluminum. I need to put the bended aluminum wrapping on myself. Thus the question of nailing and caulking.
I am posting 3 pictures now: First two are my windows to be wrapped.Did I say that the contract started with one window on the top wrapping..?
nailing aluminum flashing before caulking-img_20121031_164442.jpg   nailing aluminum flashing before caulking-img_20121031_164454.jpg
hohadcr is offline   Reply With Quote
Old 11-01-2012, 05:13 PM   #20
hohadcr's Avatar
Rewards Points: 316
Here is a picture of a common wrapping work done to replacement windows in our area.
Old 11-01-2012, 05:20 PM   #21
Originally Posted by hohadcr View Post
There are 2x6s on top and on bottom of the replacement window, as the new windows are not as tall as the original ones. There is no wood on the either side, as there was only about 1/4-1/2inch on the sides, which was filled by the foam.
It was a horrific experience to have that contractor... and he disappeared...
Getting confusing, first you say there is no wood on the sides, know there's wood on the sides. Are you sure you do not mean there's extention jambs on the inside?
With windows that tight and no rough framing on the sides, I'm not seeing a way to trim it out.
Old 11-01-2012, 07:39 PM   #22
hohadcr's Avatar
Rewards Points: 316
If I took a picture from inside, you will see that there is extra wooden frames on the vertical left/right side, to which the new windows screw into. From outside, the brick wall covers the wooden frames.
Hope this is more clear now...
Old 11-02-2012, 12:16 AM   #23
The differance between the way the other ones where done and the way your were done is when they did the other windows they left the wood trim and sill in place like there suppost to. Just the sashes were removed and replaced.
With your they removed everything leaving just a hole in the wall then tryed to use a replacement window to fill the hole, instead of a new constrution window with flat jambs.
Here's a video on how it should have been done, and the right style window.
http://www.ronhazelton.com/projects/...n_a_brick_wall
Old 11-02-2012, 10:47 AM   #24
hohadcr's Avatar
Rewards Points: 316
The replacement windows came in not only with the sashes, but also with the frames though. Please see the pic below.
Old 11-02-2012, 10:58 AM   #25
And that's the way they should have looked, but your from the pictures I've seen do not look like that.
The old sashes and middle window deviders some out but the outside stop is left in place so the frame of the new window can be pushed up againt it with caulking around the outside of the window frame.
Yours looks like they just removed the entire window frame including the sill.
With replacement windows the sill is left in place.
Old 11-02-2012, 11:42 AM   #26
hohadcr's Avatar
Rewards Points: 316
The replacement windows are shorter than the original. Even with the sills left in place, more wood need to fill in the gaps.
I am putting up more pics of similar situations: new replacement window is shorter than the original, so people added wood to fill in the gaps, and wrap everything with aluminum. The pic below is some replacement windows done in our area by Sears.
nailing aluminum flashing before caulking-img_20121102_124336.jpg   nailing aluminum flashing before caulking-img_20121102_124349.jpg
Old 11-02-2012, 05:04 PM   #27
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Why wasn't a properly sized window installed?
I'm not crazy about what's been done here at all, but at this point to finish things off you'll cap the bottom and top, and probably just add a fat ugly bead of caulk on the sides. Other option would be to anchor a couple furring strips on the sides with tapcons, and those could then be wrapped.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 11-02-2012, 06:52 PM   #28
hohadcr's Avatar
Rewards Points: 316
Exactly! just finish it off by capping. My original question was and still is:
1. Do I nail the capping on before I caulk around the seams? I don't see any nails on other similar jobs.
2. Do I need to use hydraulic cement to glue the capping aluminum to the wooden framing on the top and bottom?
Thanks!!
Old 11-02-2012, 08:14 PM   #29
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Pros typically hide the nails behind the caulk lines when possible. Yes, nail before caulk.
Thanks!!
No.
Your welcome.
www.HomeSealed.com
the very best materials for replacement chimney flashing are? DIherself Roofing/Siding 10 04-19-2012 08:22 AM
window flashing gkaro Windows and Doors 10 02-09-2012 10:46 AM
window vs. brick arched opening vs. aluminum flashing amakarevic Windows and Doors 10 02-04-2012 02:33 PM
Flashing problems Slave Building & Construction 3 11-16-2005 03:56 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
