-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   nail flange on new patio door (http://www.diychatroom.com/f104/nail-flange-new-patio-door-167609/)
lunablue 12-28-2012 01:25 PM
Is is ok to cut the nail flange off the new replacement sliding glass patio door?
mae-ling 12-28-2012 02:51 PM
Not usually, it's how it fastens to the wall.
How do you plan on attaching it?
joecaption 12-28-2012 02:54 PM
What type siding do you have?
In most cases what's what holds it in place, keeps air and water out, once you apply the sealing tape over it.
woodworkbykirk 12-28-2012 08:12 PM
yes you can cut off the nailing flange. but ONLY if the door has hurricane straps and if you use shims and screws to fasten it to the framing
the only thing is its not as easy to seal the door to prevent leaks.. you can create a flashing flange using this product
http://www2.dupont.com/Tyvek_Weather...htflashvf.html
Windows on Wash 12-28-2012 09:41 PM
Yes.
If you are doing it via pocket/insert replacement and not pulling off the siding, brick, etc, you can put it in as pocket style door.
Pay special attention to the flashing and moisture management detailing as mentioned above.
Can you post up a picture?
Gary in WA 12-28-2012 10:40 PM
I agree, if you absolutely need too... score both sides of the flange with a utility knife and bend it back-and-forth a few times.
As posted already------------------ before you cut it off----------- a picture of the application would help.
http://www.diychatroom.com/f98/how-a...to-post-20532/
Gary
HomeSealed 12-29-2012 04:13 PM
+1 to WoW's post. In fact, many doors don't even come with a flange. Be aware however, that this can make the flashing (aka: weatherproofing) of the unit a little bit more complicated and less DIY friendly, as custom bent metal is usually required.
