Mortise Lock. Baldwin - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-30-2015, 02:11 PM   #1
Rewards Points: 12
Mortise lock. Baldwin
Hi - I have a Baldwin front door lock. A single key from the outside unlocks the deadbolt and the latch lock. The mortise lock is a cylinder. Problem is that the key will turn and unlock the deadbolt but then won't turn much further unlock the latch. Any idea if this is a bad key, bad mortise, bad overall lock in general etc? Hopefully there is a simple fix and I don't need a locksmith to come out. The Baldwin is prob 25 years old.
Thx a mil
justin
jp17622 is offline   Reply With Quote
Old 08-30-2015, 04:36 PM   #2
Rewards Points: 5,336
Could be a loose/broken fitting inside the mortise box. Couldn't hurt to take it apart, if only to lube it up after 25 years. Baldwin is very good replacing parts. I had a customer who broke a flange inside the lock mortise holding the thumb latch in place. Baldwin sent out the parts at no charge after 10 years.
Try lubing the lock mechanism as well before you pull it apart.
Ron
B. Franklin 1759
Old 08-30-2015, 05:05 PM   #3
ZTMAN's Avatar
Rewards Points: 236
I had a similar issue, Baldwin just sent new internal parts, free of charge
ZTMAN is offline   Reply With Quote
Antique mortise door lock repair (possibly deadbolt problem?) ohman Windows and Doors 14 08-18-2015 10:58 PM
Mortise lock handle & deadbolt replacement creatrix Carpentry 4 06-01-2012 06:17 AM
Replacing mortise door lock without drilling grex23 General DIY Discussions 6 04-19-2012 01:39 PM
Mortise Lock drose6 Windows and Doors 2 02-25-2012 10:04 PM
looking for help with an old mortise lock Polecatt2 General DIY Discussions 12 09-19-2010 07:52 PM
