Metal Window Replacement - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-02-2012, 12:04 PM   #1
I have a 1-story ranch style home built in 1953 and need to replace the windows. The problem I'm having is all the windows are complete metal. The entire frame, sill and casing are metal. Am I going to need to take a sawzaw and cut the window out? I've looked and researched to no end and not been able to even find a picture or what type of windows these are. Being a fireman, building construction is a major part of my job and still I'm lost on these windows. Any help would be greatly appreciated. Thank you.
Here's a few pics of the windows..
THFD334 is offline   Reply With Quote
Old 02-02-2012, 12:20 PM   #2
Rewards Points: 13,270
A picture would sure be helpfull.
What type siding do you have?
Old 02-02-2012, 12:27 PM   #3
Just added a couple pics. And I have aluminum siding.
Old 02-02-2012, 12:48 PM   #4
There's a nailing fin on the outside of the window holding it to the wall.
To bad you have aluminum siding, It would simple to do if you had vinyl siding. Aluminum siding is near impossible to remove without damage to the siding.
Old 02-02-2012, 01:03 PM   #5
Is that visible or do I need to pull off part of the siding to get to it?
Old 02-02-2012, 01:19 PM   #6
Take another picture from outside.
Most often the windows go in and the trim and siding is installed after.
The only way to take the window out is to remove the siding. To do that your going to have to start at the top and remove it all to below the window.
If it was mine I would get rid of all of it and replace with vinyl siding with the same exposure.
Old 02-02-2012, 01:22 PM   #7
Ok. I'm at the firehouse today so I'll take some photos from the outside tomorrow. Thank you again for the help.
Old 02-02-2012, 01:31 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I disagree with Joe on this one. Vinyl is a bigger pain because you do have to remove all of the siding. With aluminum, just cut it back to expose the fin, remove the window, install the new one, flash properly, then add some trim boards over the area where the siding was cut back. Have a plan ahead of time for what size trim boards that you'll add so you can cut the siding to the right size.
It would be VERY difficult to R&R the aluminum siding without damaging it, and replacing a section of aluminum with vinyl would look incredibly tacky.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-03-2012, 10:11 AM   #9
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,834
That window is what we typically refer to as a "Steel Pan" window.
You can do what is commonly referred to as a frame jump in which case you would just be removing the operable portions of the window and setting the new replacement window inside the original steel jambs and interior stool/sill.
or...
You can do a full tear out by removing all of the steel frame, jambs, stool/sill, casing, etc and fully re-trim out the interior in wood. Most clients opt for this method but it is certainly less of a DIY project. Not impossible but usually outside the skillset of most home improvers.
You can cut back the aluminum siding (difficult and sometimes messy as HomeSealed mentioned) and set a full new construction with integrated nailing flange in its place. You can put a J-channel around the cut back siding and finish it out with some sort of trim detail (flat 5/4 by 4 board) or similar.
Old 02-03-2012, 10:54 AM   #10
firehawkmph's Avatar
Rewards Points: 1,822
I do like Homeseal mentioned. I use one of those twin bladed saws where the blades are counter-rotating. Good eye protection is a must. It does leave a clean cut if you're careful with it. That's the hardest part of the job. After that, window removal isn't that difficult, and if you measure ahead and make your opening the right size to allow for your trim, it goes back together nice. Something like Azek pvc trim works nice.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-03-2012, 11:37 AM   #11
I can fix that!
Rewards Points: 35
I'm dealing with a similar situation and thought the most common approach in this case was to remove the glass/panes and then collapse the frames by prying the frame from all sides (then cutting with sawzall). This pulls the the nailing flange out and will rip out/expose the nails. Then you can just put in a replacement window and use some kind of channel molding between the window and aluminum siding. Would this be OK, or am I way off?
kuhlman is offline   Reply With Quote
Old 02-03-2012, 12:34 PM   #12
Home Performance
HomeSealed's Avatar
Rewards Points: 712
That's about right, you just need to make sure that the replacement is properly flashed depending on what siding material is on the home. It might be a trick though given the aluminum siding that the OP has. We really only collapse the frames in brick. Other than that, the frame jump method that WoW pointed out is acceptable as well, and probably the easiest. You'll probably need someone to come out and wrap that after the install though, otherwise you'll see the old metal frame sitting there.
www.HomeSealed.com
Old 02-03-2012, 06:36 PM   #13
If you cut the sidng back as suggested how are you going to tape the nailing fin or install the J molding with the siding in place?
Old 02-03-2012, 06:58 PM   #14
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Its aluminum siding. You bend new J and slide it behind the siding, then caulk.
On taping the fin, you can cut the siding back far enough to allow for tape, or caulk the back side of the fin upon installation. That along with a drip cap and closed cell foam is pretty safe, especially again because its aluminum and everything will be caulked on the exterior. You have to be more careful with vinyl and the water that gets behind it... That method is at least as safe if not more so than most insert installs.
www.HomeSealed.com
The Following User Says Thank You to HomeSealed For This Useful Post:
Windows on Wash (02-04-2012)
Replacement window in progress tb582 Remodeling 13 03-11-2013 08:58 AM
need recommendations for window replacement inside old door ilyaz Carpentry 4 04-30-2010 07:16 PM
Installing window AC in metal frame sato HVAC 10 08-08-2009 10:15 AM
Window replacement - questions wahhutch9 Remodeling 2 02-20-2009 07:34 PM
Replacement Window - Nail Fin Question smoenra General DIY Discussions 12 09-04-2008 11:19 AM
