Messed Up Installing New Door Knob - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-29-2014, 10:11 PM   #1
Messed up installing new door knob
When I was installing a new door knob I screwed the latch in than without even thinking I shut the door to keep the bugs out while I stepped away for a second. Now it is latched shut with no knob and I can't install the knob without pushing the latch in. Please tell me someone knows how to fix this without breaking it!
Shingos is offline   Reply With Quote
Old 05-29-2014, 10:25 PM   #2
Rewards Points: 2,832
Can you use the trick of sliding a thin plastic card down between the jamb and door to push the latch out of the pocket.
This is how criminals enter un-invited.
Do not ask how I know this, as I will deny ever knowing this.
Could you maybe use a flat screwdriver to turn the release through the knob opening.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
curtd (05-30-2014)
Old 05-29-2014, 10:31 PM   #3
Rewards Points: 45
Insert a screwdriver into the hole where the doorknob goes. The part that is restricting your doorknob to fit will slide towards the center of the door when you exert pressure with the screwdriver. Push/pull the door at the same time.
RunningSparky is offline   Reply With Quote
Old 05-29-2014, 10:39 PM   #4
Attachment 85491
Thank you so much! I can't believe I didn't notice that
Old 05-31-2014, 08:48 AM   #5
homeremodelguy's Avatar
Sometimes the simplest things are the solution. Lol.
homeremodelguy is offline   Reply With Quote
Old 05-31-2014, 09:00 AM   #6
Rob
Robpo's Avatar
Rewards Points: 826
You will just have to wait until someone comes by to let you out/in.
Robpo is offline   Reply With Quote
Tags
door knob install
Installing pre-formed shower base pan svaic00 Plumbing 4 05-22-2013 07:08 PM
Installing vinyl fenching over chain link? rbove8 General DIY Discussions 3 05-02-2011 09:54 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 06:19 AM
Installing laminate around doors??!! RonR Flooring 8 01-05-2008 07:38 AM
