Master Bedroom French Doors Will Not Latch - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-18-2012, 07:25 AM   #1
I have french style doors in my master bedroom. One side has a verticle slide lock on top of the top. Them main door has the locking door knob.
When I close the door, the deadlatch will not secure into the strike plate.
I have tried tightening all the screws on the hindges as well as the screws holding the knob in place.
Any recommendations on how to solve this issue?
Wing2012 is offline   Reply With Quote
Old 07-18-2012, 09:42 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,606
Post up a picture of the door.
There is some adjust-ability in the door but it may require some shimming and in the worst case, removal and re-installation.
Old 07-24-2012, 04:34 PM   #3
There are two things to consider in this problem. One is that the door doesn't match the door frame and two the hinges isn't installed properly. You need to reinstall the door to be sure it will close.
denyoung is offline   Reply With Quote
replacing a window with french doors monicalyn Building & Construction 5 09-12-2011 01:36 PM
Reliabilt Patio French Doors from Lowe's Southernese Carpentry 7 07-10-2011 01:49 PM
french doors or sliding doors dav099 Windows and Doors 5 05-22-2011 07:00 AM
with all bedroom doors shut does thermostat read correct temp? windowguy HVAC 19 04-20-2009 08:17 AM
French Doors - Locking Dummy Levers highflyguy Building & Construction 4 10-08-2007 10:35 AM
