Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 04-06-2012, 11:19 AM   #1
Masonite Door Lite removal
I have a Masonite HD Steel door with a Door Lite (window) in it and I was curious if I can remove the window before I paint the door, or do I have to try and paint the door with the window (trim) still in the door?
There is 12 screws holding the window in, and I have a pack of plugs that go in the screw holes, which suggests to me that it's ok to remove the window for painting.
I'm just unsure if there was a sealant used when they put the window in.
bcdemon is offline   Reply With Quote
Old 04-06-2012, 11:34 AM   #2
A royal paint to remove the window and it would break the sealent that stops it from leaking.
Just use a quality 2-1/2" sash brush, your going to need one anyway to paint the low spots on the door panels.
PaliBob (04-06-2012)
Old 04-06-2012, 12:54 PM   #3
ya its a pain peeling the window out of the door but it is possible. just leave it in and use a good brush or buy some good quality painters tape like frog tape and tape it up good.
princelake is offline   Reply With Quote
Old 04-07-2012, 08:39 AM   #4
Thanks for the advice. Maybe I'll try out my new spray painter.
Thanks again.
Beware Masonite doors Jeremy Hillary Boob, PhD Building & Construction 14 03-14-2013 11:01 PM
Hardie over Masonite siding??? canyonbc Remodeling 2 01-27-2010 09:57 AM
Can I tape joints on old masonite walls? ETD66SS Building & Construction 9 11-13-2009 06:09 AM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
