Making A Doorway Wider - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-10-2012, 07:21 PM   #1
Making a doorway wider
I just bought an old house and the back door is badly nroken so im going to get a new pre hung door to replace it. The door in there is only 30 inches wide and i want to put in a oor 36 inche door instead. How hard is it to make the doorway wider?
wnyrob is offline   Reply With Quote
Old 03-10-2012, 07:31 PM   #2
Rewards Points: 528
Depends?
framer52 is offline   Reply With Quote
Old 03-10-2012, 09:13 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Anywhere from pretty easy to a royal pain.
titanoman is offline   Reply With Quote
Old 03-10-2012, 09:22 PM   #4
Rewards Points: 13,750
What type siding do you have now?
Not really a great first time DIY type job. Just to many things to go wrong.
Old 03-11-2012, 07:24 AM   #5
DIY staff
Rewards Points: 7,174
You will need to open up the inside to examine the framing---I suspect this is an older house --that size door has not been common for many years.
Windows on Wash (03-11-2012)
Making a 2nd doorway yergtm Building & Construction 5 08-09-2011 07:12 PM
Default Making a doorway bigger goku8586 Building & Construction 7 07-05-2011 08:09 AM
adding bifold doors to a 59" doorway diy'er on LI Remodeling 14 11-12-2010 08:08 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Making a doorway into a display unit Susie Carpentry 2 10-13-2006 07:37 PM
