Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 12-13-2011, 03:58 PM   #1
Lowes replacement sashes
Our ranch house has early 1970's double hung windows. They're fine, but single pane.
At Lowes they offer replacement sashes. You measure your window opening and they make them to fit. I priced one with low-e glass, argon filled, and wood frames and the guy said $200.
The brochure says you take out the old window and then install new slides and then the sashes, which are double hung and tilt in.
Anyone ever do these? I'm interested in how difficult (i.e., how time consuming) they are to do, and how they look. The guy suggested getting just one to make sure they work, which isn't exactly re-assuring.
pyper is offline   Reply With Quote
Old 12-13-2011, 04:10 PM   #2
Exterior Construction
Windows on Wash's Avatar
You are referring to what is called a sash kit. It provides the new jamb tracks, balances (often time tension fit) and new sashes. They are cheaper than replacement window, not by much usually, but can be difficult to get in properly.
If they are not done properly, the will leak like a sieve. Have you considered a storm window if you are not thinking replacement. They are a bit easier to install correctly.
Old 12-13-2011, 04:49 PM   #3
Hi, Thanks,
We have storm windows. My wife strongly dislikes them.
I suggested just taking the storms off and having higher heating bills, but she wants new windows.
The house is brick. The replacement windows I've seen in brick always seem to involve smaller sashes by about 1.5" all around. I don't like that.
Old 12-14-2011, 06:22 AM   #4
Take a look around. There are some narrower profile replacement windows out there that will not cost you much glass.
Even the vinyl line that we use only shrinks the opening by about 3/4" a side.
If you went with Fiberglass, that can be as little as 1/2" a side.
Sash kits are fine, but they are notorious for not sealing right and very finicky to get in properly.
Old 12-14-2011, 09:31 AM   #5
Windows & Remodeling
HomeSealed's Avatar
+1. I don't like sash-kits at all. We actually do several jobs per year where we replace them because they leak air... You are in the price range of a half-way decent diy replacement window already (depending on options), that is the route that I'd go.
HomeSealed is offline   Reply With Quote
Old 12-14-2011, 11:08 AM   #6
Good to know.
So where do I go to see samples of replacement windows that won't lose too much glass?
Searching for windows on the internet it difficult, because so many of the links are for the Microsoft product. Doh!
Old 12-14-2011, 11:45 PM   #7
HomeSealed's Avatar
Where are you located?... That will dictate which products are available to you. Okna, Sunrise, Softlite Pro, and Gorell Timeless are all good, slim-lined options. You can do a zip code search on most manufacturer websites to see if they serve your area.
Old 12-15-2011, 10:40 AM   #8
South Carolina.
I'll check into the ones you mentioned.
Old 12-15-2011, 11:33 AM   #9
waterman1971's Avatar
What type of windows are in the house now?
What type of glazing?
You may be able to order the double glass and use different glazing on the existing sash.
waterman1971 is offline   Reply With Quote
Old 12-15-2011, 01:33 PM   #10
They're wooden 70's vintage single-pane divide lite. The sashes move up and down in spring loaded aluminum tracks.
Each sash has 6 panes. I think there are 16 windows on the main floor, and 11 in the basement. We will probably leave the basement unchanged.
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 05:46 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 03:24 AM
Replacement windows not going to work? AnthraciteDude Building & Construction 9 12-11-2010 12:43 AM
Lowes Reliabilt 3500 (Atrium 8700) a decent vinyl replacement window? lffisher Building & Construction 2 08-24-2010 06:55 PM
Replacement latches for tilt in sashes ConstantChange General Discussion 7 11-19-2006 05:35 PM
