Leaky Vinyl Picture Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 06:51 PM   #1
Leaky vinyl picture window
Hello all,
I am just finishing a new laundry room and the window on the south side is leaking. It is a picture window and leaks on the inside from about the center of the window and to the left. It only seams to leak when we get heavy rain and wind. I thought that maybe the water was getting in through the channel inside the window so I tried plugging the top weep holes at first and then the lower ones but it still leaks. There is no water on the top or sides of the window just under it. The water is not coming past the window seal either. I have attached some pictures as well.
Thanks for any help.
Leaky vinyl picture window-dcp_4187.jpg   Leaky vinyl picture window-dcp_4186.jpg   Leaky vinyl picture window-dcp_4184.jpg   Leaky vinyl picture window-dcp_4188.jpg
glpzez is offline   Reply With Quote
Old 04-12-2013, 07:11 PM   #2
Rewards Points: 14,010
Who installed this window?
Was there a nailing fin?
Was window tape used?
No caulking around the outside of the frame?
Odd looking window, first place I would suspect a leak is in those two outside corners where the seams are.
Why would you seal up the only way for water to leak out if it got inside the frame?
Old 04-12-2013, 07:14 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,258
Get a closer picture of the exterior and look for blocked weep holes.
Old 04-12-2013, 07:17 PM   #4
Rewards Points: 2,240
All of the above.
Look at the trim and whatever flashing is above it.
rossfingal is offline   Reply With Quote
Old 04-12-2013, 07:30 PM   #5
The O/P said they caulked up the weep holes.
I've never seen weep holes at the top of a window as they suggested they caulked up.
Old 04-12-2013, 07:57 PM   #6
Well first off, the grace flex flashing isn't done correctly.
jsbuilders is offline   Reply With Quote
Old 04-12-2013, 08:01 PM   #7
Where's the Z moulding over the window?
Old 04-12-2013, 08:09 PM   #8
Didn't read the full post.
If the weep holes are on the top, the window is installed upside down. Couple that with the fact that they are now blocked, the window is going to leak around the IGU regardless.
It appears to have the potential to leak at the wood/home interface but is sounds like it is somewhat hosed on all accounts.
Old 04-12-2013, 08:17 PM   #9
If you zoom in on the picture you can see the weep holes are on the bottom.
Does it have a new construction flange, or is it a replacement, if it's new construction the grace should be over the flange on the sides and top. a bead of caulk run around the opening, remember to never seal the bottom, then the window put in.then flashed
Old 04-15-2013, 03:50 PM   #10
Thanks guys,
First of all I this is my first time at using a form so please forgive any errors I am making.
I installed the window and i live on the Oregon coast. The window does have a nailing flange. I first wrapped the window opening with grace and then caulked the back side of the flange and attached the window to the sheeting. I then taped around the outside of the flange to the grace. Then I installed the 30 lb tar paper. Then I cut the trim and caulked the back side of the trim and installed it over the tar paper. I did install flashing at the top of the top trim. I them caulked behind each piece of siding I put up. To address the weep holes. I removed the vinyl strips the cover the window around the outside of the window. Once removed it exposes where the water drains down into the channel in the window and out the weep hole at the bottom of the window. I tried caulking the first set first and then the normal weep holes just to see I I could determine if maybe I had a leak in one of the corner seams.
Old 04-16-2013, 07:02 AM   #11
Caulking the weep holes will certainly facilitate a leak.
Oak casing to a vinyl jamb extension on a new window? Dustball Carpentry 13 04-14-2010 11:06 AM
Vinyl Window Replacement aschau01 General DIY Discussions 2 12-23-2008 05:17 PM
Window Frame Materials - Vinyl vs Aluminum vs Fiberglass chrison600 Building & Construction 2 10-09-2005 11:13 AM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
