Leaking Under Garage Service Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-18-2014, 05:26 PM   #1
Rewards Points: 462
Leaking under garage service door
My house was built less than 4 years ago. Shortly afterward I discovered water running into the garage from under the threshold of the service door. The builder sent someone over to remove the door, caulk underneath and then reinstall it. It was still leaking so they came back and did it again. It seemed fine after that but now it is leaking again and it's too late for the builder to do anything more. Last time I saw water in the garage I thought it might be coming from the opening along side of the threshold so I put expanding foam in it, but that didn't help.
Being that I want to do this only once, what would the proper way to handle it? I assume take out the door frame, clean the concrete and underside of threshold, and then fully caulk between the threshold and the concrete. Am I correct?
What would be the recommended caulk to use for this?
Richo is offline   Reply With Quote
Old 06-18-2014, 05:49 PM   #2
Rewards Points: 12,818
Need a picture of the outside not the inside.
Door thresholds should never be even with any solid surface outside the door if it's not covered with a roof.
100% sure way to always have water problems.
Caulking is not the fix, it will always fail.
Old 06-18-2014, 06:08 PM   #3
Rewards Points: 462
The door only leaks when there is a lot of rain and probably happens when it is blowing at the door. There have been many times it has rained a lot with no water coming in.
Old 06-18-2014, 06:43 PM   #4
Rewards Points: 416
I doubt the rain is coming under the threshold but rather between the door and threshold. Test this theory by placing a 1"x 1" between jambs cut to length and against the door on the outside. This creates a wind direction change of 90 twice before it can enter and air despises direction change.
At one time in the history of exterior doors there was a replaceable seal in thresholds that sealed water out very well. And then someone decided that was just ugly as sin and begin putting the no good seal in the door, and now you know the rest of the story. But lucky for us, those butt ugly thresholds are still available.
Old 06-18-2014, 07:55 PM   #5
Rewards Points: 462
Just any piece of wood that is 1" square? Nominal 1 X 1 (3/4 square) or actual? How high from the threshold should it be placed?
I suppose I could also test this by creating my own rain with a hose however, a lot of rain is forecast in the next few days.
Old 06-18-2014, 08:04 PM   #6
The correct way to have installed that door is with a jamb sill.
Or at least flashed it correctly.
http://jambsill.com/
Old 06-18-2014, 08:34 PM   #7
Rewards Points: 416
From what I can see in the picture the threshold has about a 1/4" rise where the door rests and most of those are made similar. So nominal 1" thick lumber will work as long as it is above the door bottom edge so the wind would need to make a 90 degree down turn there. And a 1x2 would work just as well for a test. It needs to lay on the threshold and butt against the door or as close as possible to make the air movement change direction.
The garden hose alone, in my opinion, wouldn't be a very valid test since the wind is really what's pushing the water under the door in most instances. And from my experience with weather being unpredictable we don't always get the wind direction we need so it may take more than one rain storm.
Old 06-19-2014, 12:16 AM   #8
I would also say that the water is coming in between the threshold and the door.
Corners are always the most susceptible to this. They make tapered foam corner pads that self adhere to the frame just atop the threshold that work well.
I would also recommend caulking the joint where the threshold meets the door frame on either side with a good polyurethane caulking or a paintable silicone.
uncommon doors is offline   Reply With Quote
Old 06-19-2014, 10:51 AM   #9
Rewards Points: 462
Thanks for the replies everyone. I will do some investigating and first see where the water is coming from.
Old 06-19-2014, 12:10 PM   #10
Rewards Points: 144
I don't like the way the transition from the concrete to the door was made but it is what it is.Caulk wont' fix it as was stated above.There should have been a pan under the threshold.
mako1 is offline   Reply With Quote
Garage door balance/tension EricBNeverScare Windows and Doors 2 02-18-2014 05:54 PM
Garage door stops and goes going down robert75 General DIY Discussions 0 01-29-2014 04:40 PM
Replacing garage door with wall containing window and/or door diyer101 Remodeling 9 11-23-2012 08:47 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
garage door lock jack_j General DIY Discussions 1 12-27-2006 07:40 PM
