-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Leaking Transom Window (http://www.diychatroom.com/f104/leaking-transom-window-161816/)
Chuck Wright 11-01-2012 09:25 AM
I have a 2'0 x 5'0 half moon which is leaking between the glass and fogging. Can this be repaired or need replacement?
joecaption 11-01-2012 09:39 AM
Needs replacement. Should be under warrenty if you can ID the maker.
Windows on Wash 11-01-2012 09:53 AM
Depends on how old the window is but as Joe mentioned, could very likely be a warranty issue.
HomeSealed 11-01-2012 01:41 PM
+2. Even if it is not warrantied you can probably replace the IG (glass unit) only, rather than the full frame to save some $$$.
