Leaking Basement Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-25-2011, 07:08 PM   #1
Rewards Points: 348
Leaking basement door
Can you help me diagnose why, when I go down to the basement, there is water coming in by the door? I have attached two pictures.
http://imageshack.us/photo/my-images/36/door1m.jpg/
Here you can see water seeping in under the door. Not the entire door, just one side.
http://imageshack.us/photo/my-images/268/door2t.jpg/
Here we are outside looking in. I have a bad deck here, that is leaning toward the house. It is probably a good 10 inches to a foot below the door. If you look closely, there is a cement line, where it appears large pieces of cement were kind of stacked on top of each other, forming a scar.
Above this I have a deck that obviously drips everything it gets through the flooring and onto this (about to be removed) deck. Where do you think the water is coming in from, and where would you start?
Thanks for any pointers!
dougp23 is offline   Reply With Quote
Old 09-26-2011, 05:31 AM   #2
kwikfishron's Avatar
Rewards Points: 618
Google “door pan flashing“.
You need to pull and reinstall the door with the a door pan.
You can buy plastic kits at the box stores. I have mine made out of stainless steel at a local sheet metal shop.
kwikfishron is online now   Reply With Quote
Old 09-26-2011, 07:12 AM   #3
Yes that is most certainly due to bad installation. Kwik is right with taking out the door and installing with flashing. But i would always use some backer rod and some PL Premium as extra precautions. Don't want to have the same problem all over again.
RB101011 is offline   Reply With Quote
Old 09-26-2011, 07:20 AM   #4
DIY staff
Rewards Points: 7,174
PL Premium??? Wouldn't that make the door impossible to remove in the future?
Old 09-26-2011, 08:33 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
Poor installation as mentioned.
You can look at 1-piece flexible sill wraps as well and create the proper slope with some beveled azek/siding, etc.
Old 09-26-2011, 11:51 AM   #6
Not impossible to remove just harder. But it would make it almost impossible to leak in the future.
basement leaking ptb Carpentry 3 09-12-2011 08:18 PM
Exterior door in finished basement -- size? configuration? axiom10 Building & Construction 3 04-21-2010 03:51 PM
leaking patio door jpg274 Building & Construction 2 10-30-2009 03:42 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
