Leaking Anderson Casement Window - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-06-2012, 12:27 PM   #16
concretemasonry's Avatar
Rewards Points: 2,578
It is a shame when 2/3 of the windows in new or replacement windows are installed improperly and the extra "showy" materials contain the moisture and funnel it down, to the side or even upward in the case of capillary action in the long term.
Dick
concretemasonry is online now   Reply With Quote
Old 12-11-2012, 05:05 PM   #17
Smile
Leaking Casement Window
Thank all of you for your feedback. The leak has been found using a power washer, just a hose wasn't strong enough. We had to cut a 3 inch wide x 8 ft long piece of sheetrock of the inside of the window where the trim piece was on the bottom of the window to find it. What is happening is that at high winds, water is getting by the seal where the casement crankout hardware is. It is then getting into the seam of the 2 2x4's that make up the bottom window frame and runs down those boards and out the inside seam down the wall to the living room. We bought some flex seal and sprayed the 2x4 seam on the outside and the inside and NO MORE LEAK!!!! Thank goodness. I'm just bumbed because I didn't have to remove all of the shingles and redo but what can I do, not my area of expertise. I like this website and all of the information everyone passed on. Can't thank you all enough. Think the contractor probably should have done that first but atleast it is now fixed. This has been happening since the home was built in 2007.
srthomson is offline   Reply With Quote
Old 12-11-2012, 05:22 PM   #18
Rewards Points: 2,238
Hopefully your problem has been solved!
Thanks for stopping here!
Stop back any time!
Happy Holidays!
rossfingal
rossfingal is offline   Reply With Quote
Anderson Casement Windows Problems I E S Windows and Doors 5 09-27-2014 04:27 PM
Drilling into a vinyl casement window rmh@newburgh Windows and Doors 2 11-10-2012 07:28 AM
In-swing non-crank casement window screen blee Windows and Doors 2 05-21-2011 03:42 PM
Leaking Window Gator81 Carpentry 1 09-27-2009 02:21 PM
Leaking Window Help dkylep Building & Construction 7 12-23-2008 12:57 PM
