Latch & Unlatch Patio Screen Door From Both Sides - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-07-2013, 07:00 AM   #1
Rewards Points: 2,516
Latch & Unlatch Patio Screen Door from both sides
Want to be able to latch & unlatch the patio screen door from both the inside and outside. Currently only the inside of the door has the "slide" and
the outside has only a pull.
I've looked online and cannot find the hardware for unlatching/latching from both sides of the door.
Might have to modify the existing outside pull somehow so that there is a way to operate the inner slide.
Ideas???
hammerlane is offline   Reply With Quote
Old 05-07-2013, 07:01 AM   #2
5 more photos of the outside pull taken off and the latch and catch mechanism.
Latch & Unlatch Patio Screen Door from both sides-44-outside-pull-removed.jpg   Latch & Unlatch Patio Screen Door from both sides-55-outside-pull-backside.jpg   Latch & Unlatch Patio Screen Door from both sides-66-outside-pull-off.jpg   Latch & Unlatch Patio Screen Door from both sides-current-catch.jpg
Old 05-07-2013, 09:29 AM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Not sure how much luck you'll have with that unit, it will definitely take some ingenuity and customization to make that work.
Alternatively, many newer products come with a spring loaded screen latch that operates from both the interior and exterior, and has a separate lock button on the interior. Not sure if those are available at the box stores yet, but if your door is standard size, Ohio is the replacement window manufacturer capitol of the world. I know for sure that Polaris (in OH) uses that style, and I believe that Softlite does as well. You could just pick up a new unit very cheap.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 05-07-2013, 10:20 AM   #4
Alternatively, many newer products come with a spring loaded screen latch that operates from both the interior and exterior, and has a separate lock button on the interior. . I know for sure that Polaris (in OH) uses that style, and I believe that Softlite does as well. You could just pick up a new unit very cheap.
I know exactly where a Polaris dealer is located. Will have to stop by their showroom.
Old 05-08-2013, 07:29 AM   #5
For anyone that has issues with animal scratching at the screen of the patio door, I bought an acrylic piece at HD and cut it to size. The thinnest piece was 0.093 inch. It fits perfect in the channel on the inside of the screen door frame. Used double sided adhesive tape to secure it. Been attached for about 6 weeks now and holding strong.
You can vaguely see the acrylic piece in the left photo below taken from outside. The right photos was taken from inside. With the acrylic fitting inside that channel on the door frame, it does not interfer with the opening of the door at all.
Latch & Unlatch Patio Screen Door from both sides-22-2520outside-2520pull-2520full-2520view.jpg   Latch & Unlatch Patio Screen Door from both sides-acrylic-screen.jpg
Old 05-08-2013, 07:49 AM   #6
Rewards Points: 252
Here is how I would do it (if I couldn't find a replacement handle): Make a vertical slot in the two pulls. Drill two holes in the existing slide for two rods or screws. Fashion a new slide for the outside from wood or metal and drill two holes. Fasten the rods/screws to each slide (glue, nuts, whatever). If you make the vertical slots wide enough you could probably use a nut to hold the screw to the original slide, then a nut on each side of the new slide.
shazapple is offline   Reply With Quote
Tiling a patio that already has screen enclosure. gggonzalez Flooring 4 07-05-2014 10:24 AM
Realigning patio door and repairing screen nathan.hawk Windows and Doors 9 03-02-2012 06:18 AM
sliding screen double patio doors bcrest General DIY Discussions 1 10-22-2008 07:04 AM
Concrete Patio drainage problem lakekids Building & Construction 5 07-17-2008 05:27 AM
Patio Screen Door adjustment econdave Building & Construction 3 05-30-2006 01:17 PM
